91 3.1 CAMARO WONT START
Old Feb 12, 2012 | 06:48 PM
SylusMk2's Avatar
Car: 83 Berlinetta
Engine: 2.8
drove it perfectly fine yesterday with zero problems....this morning i go to jump in it and all it does is crank dont even sound like its trying to fire.....its got new injectors,fuel pump and ignition module....help its my only car....it cant get fixed im selling it
Old Feb 12, 2012 | 06:52 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: 91 3.1 CAMARO WONT START
Is it throwing any codes?? Check engine light??
Old Feb 12, 2012 | 07:02 PM
SylusMk2's Avatar
Car: 83 Berlinetta
Engine: 2.8
Check engine light has always come on and off for the last 4 years.....its because of the exhaust....I can't afford to have a shop check the codes I gotta do this myself....and I gotta work Tuesday
Old Feb 12, 2012 | 07:10 PM
fasteddi's Avatar
Car: 1991 Camaro RS
If you have a few min do this!
https://www.thirdgen.org/service-eng...ht-error-codes
You can check the codes yourself and see whats going on in there. All you need is a good metal paper clip
Old Feb 13, 2012 | 07:41 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If it is an aftermarket ICM don't be surprised that it is bad. Did you check for spark?
Other common failures: pickup coil in distributor, ignition coil, the 2-wire pigtail that runs between the coil and the ICM.
RBob.
Old Feb 13, 2012 | 07:55 AM
clemente's Avatar
Car: new project, 86 iroc z m5
Engine: swapping to lt1 with m6
Transmission: 5 speed
Axle/Gears: will be 373 but has stock gear
i'd say start simple. take the air inlet tube off of the intake and spray some starting fluid in to see if she fires up. if she does then its a fuel issue. if she doesn't fire up check for spark. if those two are fine check timing.
Old Feb 13, 2012 | 10:14 AM
SylusMk2's Avatar
Car: 83 Berlinetta
Engine: 2.8
RBob.
it is an after market icm....i remember when by buddy replaced it a year ago (i bought the car off my good friend)they thought it was bad but it ended up being somthing else so hes running to his place to grab the origonal
Old Feb 13, 2012 | 02:25 PM
SylusMk2's Avatar
Car: 83 Berlinetta
Engine: 2.8
it started perfectly fine this morning.....ive got no idea what that was all about
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
92camaroJoe
Aug 13, 2015 06:07 AM
the_nikfive
Aug 11, 2015 02:46 AM
guy76767
Aug 6, 2015 05:58 PM
