OK, Planning period.
Old Feb 12, 2012 | 10:09 PM
backgammon7's Avatar
Car: '86 SC
Engine: 2.8
I am about to bring my Camaro back to life, as of now it needs:
New fuel tank ~$200
tank sending unit ~$200
fuel pump and strainer ~$100
Not 100% necessary, but it needs a new exhaust from the cat back. ~150-$200
I turned 18 last month and I just got my first job Saturday ( part-time, minimum wage), so it will be a few paychecks before i really get into this.
After I get the car running again, I plan to start modifying it, and seeing as how I'm in the V6 section, I might as well start with the engine.
The 2.8 is a 57,xxx mile original, and I'd like to keep it that way.
Is 300NA HP a reasonable goal for a 3.4 hybrid? I'm ok with a high compression , crazy cam motor. As long as It will run on 93 octane, it will be fine with me. If i wanted a well mannered car I would have traded the thing for a Camry.
We can talk finer points when I get closer to actual engine building, but I just want to be sure I'm headed in the right direction.
Thanks,
-Josh
Old Feb 12, 2012 | 10:15 PM
project89's Avatar
Re: OK, Planning period.
save some money and goto the junkyard and get urself a 4thgen tank assembly, its a boltin deal and u dont have to worry about rust since its a plastic tank
Old Feb 12, 2012 | 10:24 PM
Car: '86 SC
Engine: 2.8
Did all the 4th gens get the plastic tanks or was it just the LS1's? I read somewhere that only they got the plastic tanks, and that that the older style pumps and sending units aren't compatible with them. If there was an LS1 in my area I would have already grabbed the tank out of it, but the only fourth gen in my area was a base model that had a 3.4 in it.
Old Feb 12, 2012 | 11:25 PM
project89's Avatar
actually im not sure to be honest, ud just have to goto the junkyard and take a look under a car and see
actually i take that back i helped a friend install a 255lph pump in his lt1 car and it had a plastic tank
Old Feb 13, 2012 | 03:36 PM
Car: '86 SC
Engine: 2.8
The fourth gen tanks bolt in, but they aren't plug and play.
https://www.thirdgen.org/forums/ltx-...plastic-2.html
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
Zell1luk
Sep 29, 2015 10:36 AM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
