Bosch II or Bosch III Injectors?
Old Feb 23, 2012 | 04:13 AM
RS90CAMARO's Avatar
I have to take the intake off again to fix a vacuum leak and I want to change my multec injectors since they keep shorting out. Which injectors do you guys recommend bosch II or bosch III ? I searched but what I read is about changing the flow rate or switching to fords I'm looking for 15lb replacments.
Old Feb 24, 2012 | 01:42 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Bosch II or Bosch III Injectors?
I prefer the injector that has the same length and mounting as the stock ones. The gen III's tend to be slightly shorter and don't have the retaining clip groove.
RBob.
gta892000
Aug 11, 2019 11:16 AM
92-Formula
Dec 12, 2015 10:34 PM
lethaldomestics
Sep 21, 2015 01:18 PM
rubyred88
Sep 17, 2015 02:19 PM
webeeZ28
Sep 14, 2015 12:00 PM
