2.8 crank in 3.1 block
Old Feb 24, 2012 | 09:11 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
I was told a 2.8 crank out of a 85 s10 would work in one of my 3.1 blocks.they said I could use my 3.1 rods and such.does anyone know much about that?My 3.1 had a bearing go out and I think I got everything to put a 3.1 tpi together exsept the gaskets and new bearings.the cylinders in this 3.1 still have the honeing in most of them and no lip at the top.Rings even looked almost new.
Old Feb 24, 2012 | 09:17 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: 2.8 crank in 3.1 block
Depends on the '85 crank. Some information says that early '85 cranks are small journal, and that later '85 cranks are large journal.
So you will need to verify the crank journal size to know for sure.
The rods in both the 2.8L and the 3.1L are the same, the pistons, however are different, partly because of the shared rod length.
Old Feb 25, 2012 | 07:35 AM
ex-x-fire's Avatar
Its just easier to get another engine, alot of guys swap out these engines, so they are not rare. I'd do a 3.4 swap.
Old Feb 25, 2012 | 07:55 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Dude, with as many 3.1 engines that are out there, just get a 3.1 crank... The 3.1 pistons are dished and the wrist pins (that go in the piston and hold it to the con rod) are offset from the 2.8 pistons. I believe you'll be losing .030" in top piston height, IIRC, if you just slap in a 2.8 crank (provided you have the 2.8 HO crank and not the 2.8 weak crank...).
Old Feb 26, 2012 | 04:20 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
I just have these laying around and was wondering if they might go together.I havn't sean any 3.1's around here.there not very comon.the 3.4's a little easyer to find but this was just a pet thing I was thinking about to learn with.Thanks for the input.I've never put an engine together.Have done a 3.4 swap with great sucsess.
Old Feb 26, 2012 | 04:23 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Um, I'm sure there's probably a TON of 3100s, seeing as how they literally came in EVERYTHING short of pickup trucks (only difference between the 2 is the notches for the 7x sensor in the center of the crank). 3.4 uses the same crank, BTW, so if you find a blown one, the crank may be salvageable.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
rjcme
Sep 5, 2015 01:23 PM
