cant get these stupid injectors out
Old Mar 12, 2012 | 12:28 PM
91camaroRS3.1's Avatar
Car: 86 T/A
Engine: 305c.i. carbed, highrise, compcam
Axle/Gears: idk..
iv got the fuel rail off. now i cant seem to figure these stupid reatiner clips off....my manual says turn um and another thread says turn um, but i turn the clips as far as i can and the fricken injectors aint loose...rrrr
1991 Camaro RS 3.1
Old Mar 12, 2012 | 12:40 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: cant get these stupid injectors out
once they are turned they can be removed from the fuel rail. the old o-rings are more than likely swollen and causing it to be difficult to remove. pb plaster or wd40 would help aid in removal you can start to rock the injectors while pulling to aid in removal.
Old Mar 12, 2012 | 12:42 PM
Car: 86 T/A
Axle/Gears: idk..
so i turn the clip thing away from the injectors then just pull straight down? do you have a diagram or something? im a very visual learner
Old Mar 12, 2012 | 12:46 PM
Engine: Lb9
Transmission: M20
Old Mar 12, 2012 | 12:47 PM
Car: 86 T/A
Axle/Gears: idk..
turn number 87 on the pic then yank the son of a b outa there?
Old Mar 12, 2012 | 12:49 PM
Engine: Lb9
Transmission: M20
yes turn 87 to release and pull on the injector
Old Mar 12, 2012 | 12:51 PM
project89's Avatar
twist the injector back and forth as u pull on it.
another trick is to spray a ton of wd-40 or similar oil into the fuel rail
Old Mar 12, 2012 | 01:01 PM
Engine: Lb9
Transmission: M20
Old Mar 12, 2012 | 01:07 PM
project89's Avatar
Originally Posted by tunedperformanc
and whats wrong with that?
Old Mar 12, 2012 | 01:16 PM
Car: 86 T/A
Axle/Gears: idk..
allright, i might be being a puss and not pulling hard enough but im afraid to mess suin up... here a video of whats going on
http://youtu.be/VIr2akUoMBk
Old Mar 12, 2012 | 05:17 PM
GreenCamaro13's Avatar
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
ok, mine was hard as well, reason being is that from them being old and being in there a long time without lubrication and the heat it sorta "super glues" the orings to the fuel rail. what i did on mine was got come pliers and from the neck of the fuel injector i pulled down and they popped off, dont be afraid to push a little, they have taken a beating from being in the engine
Old Mar 12, 2012 | 05:33 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Its been a while since hes been back on here, I hope ya got them off man.
When that clip turns and removed...you should be able to rock them back and forth. But they are old and you know that old things can be a real PITA!
But at least the clips on the wire harness will be easy to get out...
Wait untill you try to get the clips back in Not to joke but the first time I replaced injectors on my car it took longer to get those 6 clips back in then to take all the stuff off to get to the injectors. Alot of cuss words and a few beers later..mission accomplished Im not sure if I was just a idiot but I hated putting those things back in(clips)
Old Mar 12, 2012 | 06:43 PM
Car: 86 T/A
Axle/Gears: idk..
sorry for the delay wife took off for a bit. i didnt get back on um and its dark out now. tommorow ill just muckel down on them coontz and hope for the best...worst comes to worst theres a set on ebay for 65 bucks...in the am, here goes nothing
Old Mar 12, 2012 | 06:45 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
or you can always get them cleaned up yourself man, but if there new ones for 65 thats not bad at all.
Old Mar 12, 2012 | 06:48 PM
Car: 86 T/A
Axle/Gears: idk..
no there not new there just cleaned up ones. ill clean them no matter what sence i got um outa there but im afraid i might break suin..thats my curse..imma total egore..lol i thouch it and its frail, it breaks...lol
Old Mar 12, 2012 | 07:12 PM
fasteddi's Avatar
Car: 1991 Camaro RS
At least I sold you ones less then a year old for cheep... Fresh ones!
Old Mar 12, 2012 | 07:15 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
hell yea man, best invesment ive made.
Old Mar 12, 2012 | 07:20 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Well I got the ones I have now for a deal from a guy on here so even though I paid out the A$$ for those a year ago, I figured I'd return the favor. I paid like 200 Bucks for those ones I sold you..LOL.. But you needed them and I got bigger ones for the turbo build for a great price. So its a win win situation
Old Mar 12, 2012 | 07:28 PM
Car: 86 T/A
Axle/Gears: idk..
green i seen a post you made selling stock ones..still got um?
Old Mar 12, 2012 | 08:17 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
yea man, but they dirty, you would have to clean em up,
Old Mar 12, 2012 | 08:18 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Old Mar 13, 2012 | 12:34 PM
Car: 86 T/A
Axle/Gears: idk..
GREAT SUCCESS lol turns out i was trying to turn them the wrong way. lol got um out now imma clean them up. imma go get a fricken ohm meter and a fuel presure sensor tonight. BIG QUESTION, can i just get a biek tire presure tester to test it? 5 bucks..and it goes up to 60 psi..
Old Mar 13, 2012 | 01:10 PM
Engine: Lb9
Transmission: M20
not sure what your trying to do other than start a fire. you cannot use a tire gauge on your an -4 fitting to test fuel pressure. If you want to check fuel pressure buy a fuel pressure gauge Actron CP7818
Old Mar 13, 2012 | 04:45 PM
Car: 86 T/A
Axle/Gears: idk..
well i didnt know lol, im no expert...lol ill buy the fuel presure guage..or rent one if i can
Old Mar 13, 2012 | 04:48 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
yea autozone is usually rents tem out BUT they ask alot to put for securtiy. over here when i was goign to rent one they wanted to charge me 69$ and i would get it back but its just too much just to rent the part,
Old Mar 13, 2012 | 05:30 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Takes a few minuets to check fuel pressure, if you start it and drive it also, so as long as you bring the tool back to the autozone. Its basically free rental. Cant beat that. Ive done it and actually they just let me use it in the parking lot and I gave them my ID when I used it to drive arround the block. This was like a year ago, but like I said if you dont have the $$ to buy one, those parts stores that let to rent/borrow tools saved me many times over.
Old Mar 13, 2012 | 05:32 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
the problem with the autozone here was that they didnt have one open atm so they wanted to charge me for opening it
Old Mar 13, 2012 | 06:03 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Thats crappy.LOL freaking auto places sometimes....
Old Mar 13, 2012 | 07:52 PM
Car: 86 T/A
Axle/Gears: idk..
im an ex-autozone employee. lol not from bad things but cuz i moved. so im VERy loyal to them haha. i went by and to rent its frick 70 bucks like you said. but they have ones for sale for like...30 bucks haha
ill just end up buying one after i get it put all back together. i went and got the multi meter but guess what i have no fricken idea how to use this thing....lol
This is the one i got..i got it put together but idk what to set the switch too....lol maby yall can zoom in on the pic and fill me in..sorry for me incompitant..the directions suck....thanks guys
http://www.autozone.com/autozone/acc...fier=64471_0_0_
Old Mar 13, 2012 | 08:31 PM
fasteddi's Avatar
Car: 1991 Camaro RS
http://www.autozone.com/autozone/acc...ier=64471_0_0_
If you have problems with the meter just ask me and vid tape your issues.
Read the directions!! And start with high volts or low ohms when testing things. If it doesnt read then just work your way up or down on the scale. But since this is all 12vts stuff i wouldnt really worrie about the Volts, just set the volts to 100vts on the scale if thats what it has on it.
And for god sakes dont test the amps on anything unless you put it in series with the line out of the load, if you dont know what that is then dont check amps. Or you meter will either pop a fues or just die.
I work in HVAC and use meters(although mine are 300+$ ones and there autorange so even a kid could use them) I use them for literly everything!!!!!!!!!!!!!!!
Old Mar 13, 2012 | 08:35 PM
Car: 86 T/A
Axle/Gears: idk..
ok well i got them bad boys soakin over night in some injector cleaner to loosen any crap in them. they were pretty dirty lookin to me so hopfuly that will help. i guess i shoulda tested them before spending the time to clean um but..ya know how i roll....lol ill fill yall in tommorow...as for me...my wifes calling
gnight fellas
Old Mar 29, 2012 | 02:14 AM
thunder69n's Avatar
Car: 87 Firebird Auto V6 2.8l
I have that same voltmeter, and I am sorry to see someone else bought it. It does not have an audible continuity test. And its really hard to pick up measurements depending on having the pock sticks in the perfect spot, not great for diagnostics .
I finally realized I could unclip the wiring for the injectors so I could life those fuel lines and Fuel rail out, when I was playing with mine, I couldn't get my fuel injectors back on after I played with mine, untill I removed completely from car.
Old Mar 29, 2012 | 08:29 AM
Car: 86 T/A
Axle/Gears: idk..
yes getting them back in the fuel rail was the easy aprt for me. lol lining them up and getting them all to fit snugly in there little holes with no leaks whas the trucky parts. lots of twisting pushing yanking walking around both sides fot he car. but as far as the multi-meter i found that it worked great for me. i took the inejctors out of the car soaked them in carb/injectors cleaner over night, dryed them off and shined them up in the morning then were the electirc would hook up i just put one prod per rod lol..mine worked well.
Old Mar 29, 2012 | 02:42 PM
fasteddi's Avatar
Car: 1991 Camaro RS
They sell aligator attatchments for some of the VOM probes to help get a good connection for troubleshooting, and alot of meters now have a audiable sound for Ohms. Sometimes you have to actually buy new probes and the aligator attatchment actaully screws into the ends of the probes.
I have a very nice Fluke meter but I only got it for HVAC troubleshooting, but any meter that is true RMS autoranging is a great meter to have, but they are sorta pricey. My Meter kit cost 250 bucks out the door so thats a crazy amount but when you use it basically everyday all day its needed. And the attatchments for clamp on tempeture probes and the clamp on amp meter was another 200 bucks! Freaking amazing what some items cost these days.
Also make sure you always ISOLATE the componet your testing resistance on as if try to ohm your injectors in the future and you still have them connected(which is really hard to do) your reading will not be true, as its picking up resistance.
Old Mar 29, 2012 | 03:06 PM
Car: 86 T/A
Axle/Gears: idk..
my el-cheapo seemed to do the trick just fine for me...just took me a min to findout how to use the fricken things..directions sucked, haha
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
