3.1 PaceSetter Headers problem
Old Mar 13, 2012 | 08:24 AM
Reni-Camaro's Avatar
Car: Camaro 1988
Engine: 305 14.5s 1/4mile
Axle/Gears: 2.73 LSD
I have a problem with a mixture of fuel!
I have PaceSetter Headers.
I changed the MAP sensor 1bar (it did not help)
No check engine
My spark plug black
I read ( https://www.thirdgen.org/forums/v6/5...ost-power.html ) what may be a problem in the O2 sensor without heating!
I'm illiterate in english sorry!
http://vimeo.com/37272507
Old Mar 14, 2012 | 12:13 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: 3.1 PaceSetter Headers problem
Probably running rich, some people seem to be fine without a heated o2 sensors when running headers, others seem to have issues. I would verify your o2 readings and AFR if possible and go from there, or you can try throwing a heated o2 at it, if it ran fine before that will probably sort it out.
Old Mar 14, 2012 | 03:50 AM
Car: Camaro 1988
I do not have the program read ECM my 3.1
Street Lethal
Apr 30, 2019 12:14 PM
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
the_nikfive
Aug 11, 2015 02:46 AM
guy76767
Aug 6, 2015 05:58 PM
