2.8 coil
Old Mar 27, 2012 | 09:54 AM
stang9150's Avatar
2.8 coil
I have a 1987 firebird with a 2.8.How do I swap out the coil,what bolts hold the bracket on?The new one came with 2 straps and bolts so I know I have to drill out the rivets.Any idea how to get this thing off?Thanks
Old Mar 27, 2012 | 11:44 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: 2.8 coil
IIRC the bracket is bolted on to the exhaust manifold. Once you get that off, you then just drill lut the rivets then bolt the new coil in place and reassemble.
Old Mar 27, 2012 | 03:46 PM
stang9150's Avatar
Re: 2.8 coil
I can't seem to find the where this bolt for the bracket is, 1 bolt or 2?
Old Mar 27, 2012 | 03:55 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: 2.8 coil
don't use that location, relocated it up high where its not being cooked by the exhaust. so you can leave the old one right where it is. Plug wires into new one and figure out a new spot by how much slack you got.
mine is bolted to cowl.
Old Mar 27, 2012 | 03:59 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Re: 2.8 coil
2 bolts on the passanger side manifold. You might have to dig a little. My engine bay is pretty bare. Got rid of alot of stuff i dont need
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
usafirebird
Sep 29, 2015 11:58 PM
