4L60E swap?
Old Mar 26, 2012 | 10:00 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
4L60E swap?
whats needed to swap one of these into my car? is it harder than doing a 87 up tranny?
Old Mar 26, 2012 | 10:17 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: 4L60E swap?
You will need a tranny controller, other than that, it fits just like a 700R4.
Old Mar 26, 2012 | 11:43 PM
project89's Avatar
Re: 4L60E swap?
u can use the 4l60e without an ecm but it requires a full manual valve body
Old Mar 27, 2012 | 03:06 PM
Engine: L31 350
Re: 4L60E swap?
How do I install the controller?
Old Mar 27, 2012 | 05:43 PM
project89's Avatar
Re: 4L60E swap?
tci makes a very nice controller but its alot of money
imho u would be much better ahead having a stock 700r4 rebuilt y a reputable place
like dana @ probuilt he is a sponsor on the boards
Old Mar 27, 2012 | 06:06 PM
Engine: L31 350
Re: 4L60E swap?
Well reason I want to get away from thr 700r4 is because since mines an 86 it has the slamming problem and thr newer ones don't since they have the anti abuse valve
Old Mar 27, 2012 | 06:17 PM
Re: 4L60E swap?
Then swap in a later 700R4.
The 4L60E is just an electronically controlled 700R4.
Old Mar 27, 2012 | 07:15 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: 4L60E swap?
only time you would hear me say its not worth the trouble to put that in a V6 car..... if money is buring a hole in your pocket get a 200 4R built proper [better gearing] or do a T5 swap.
Old Mar 27, 2012 | 08:41 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: 4L60E swap?
...and a harness and some adaptor cables to pick up the TPS signal etc. Also you might have to do something with the speedometer input. I like the 200 4R idea for what you are doing.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
C409
Sep 1, 2015 03:42 PM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
