What it this? and why is it leaking?
Old Mar 29, 2012 | 01:06 AM
cha_chard's Avatar
Car: 89 Camaro RS
Engine: 2.8L V6 MPFI
Transmission: 5Speed
so i have this oil leak from this thing on the side of my oil pan, i have no idea what it is, there is no wire going to it or anywhere close,
thanks
Old Mar 29, 2012 | 01:35 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: What it this? and why is it leaking?
Oil pressure sending unit, maybe. If so it is missing entirely. I can get under mine and get a picture for you tomorrow if you like.
Old Mar 29, 2012 | 01:49 AM
cha_chard's Avatar
Car: 89 Camaro RS
please do, and could you also show me where the wire comes from, so i can try to find it?
Old Mar 29, 2012 | 02:02 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Odd. These cars never came with a sensor in the oil pan to the best of my knowledge. That is definitely not an oil pressure sensor or switch. Oil would not have a pressure reading in the oil pan. The oil pressure sensor is in the side of the block above the oil filter or on the rear of the block by the distributor. I would say this was aftermarket but because of the indentation of the pan around it this makes me wonder if it was an aftermarket pan? That sensor is most likely either an oil temperature sensor or a oil level switch.
Old Mar 29, 2012 | 05:52 PM
cha_chard's Avatar
Car: 89 Camaro RS
ya i thought that too, but there is no extra gauge or light anywhere on my dash??
Old Mar 29, 2012 | 06:04 PM
ex-x-fire's Avatar
Its an Oil level switch. Pan must have been swapped out at one time. Looking at how close the exhaust pipe is to the pan, I'd say its not the right pan.
Old Mar 29, 2012 | 06:07 PM
cha_chard's Avatar
Car: 89 Camaro RS
any suggestions to help stop the leak?
Old Mar 29, 2012 | 06:10 PM
ex-x-fire's Avatar
It got a gasket just like a drain plug, unless the sensor is leaking, you should beable to seal it up.
Old Mar 29, 2012 | 06:25 PM
cha_chard's Avatar
Car: 89 Camaro RS
wait, so you guys think its aftermarket?
Old Mar 29, 2012 | 07:35 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Yes.
Now that I think about it, that is probably an oil pan off a LT1 camaro 93-97. The stock pan probably got damaged somehow and the previous owners got a new pan from a salvage yard. So they probably never wired in the sensor but left it there to plug the hole obviously.
Old Mar 29, 2012 | 07:53 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Honestly it looks just like my oil pan, but instead of a normal oil plug you have whats in your pic, just take it out and put a new oil plug in it if you just wana stop it from leaking... just my though on that.
Old Mar 29, 2012 | 08:02 PM
Engine: MPFI
I think Trav is right, not sure about the after market. Mine sending unit is not on the oil pan. Trav was right. My bad..
Old Mar 29, 2012 | 09:15 PM
project89's Avatar
well if he has a 350 or 305 in his car that might be the case, but seeing how he posted in the v6 section im assuming its not a v8.
that looks like an oil level sensor that they use in the oilpans off the 3.4
so maybe somone swaped a 3.4 into ur car or used the oil pan off a 3.4.
i dont remember if the sensor threads were pipe plug or not but im pretty sure they are, remove the sensor and take it to ur local autoparts place and they should be able to give u a pipe plug that fits in the hole.
just dont remove the plug and drive the car there
Old Mar 29, 2012 | 09:17 PM
project89's Avatar
just looke dat the picture again, that is deffinatly an 3.4 oil pan, they are deeper then the stock 2.8/3.1 pans and will be very very close to the ex system if used with the 3.1/2.8 ex system
Old Apr 1, 2012 | 11:06 AM
cha_chard's Avatar
Car: 89 Camaro RS
ya, its a 2.8, ill see if i can get under it and just take it off, and put a plug in, would it be worth it to grab an old oil pan from the wreckers? or just leave it as is?
Old Apr 1, 2012 | 12:56 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Plug it off, make sure it doesnt leak, and call it a day. IMO
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
