vacuum leak
Old Apr 13, 2012 | 06:05 PM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
vacuum leak
Ok, I got a weird vacuum leak.
but first the setup.
a in a 91 camaro Rs.
a 3.4 base block dressed up as a 3.1.
pacesetter headers
milled heads
comp cam 260H cam ( complete kit )
airpump delete pulley. ( removed vacuumline completely, it goes now from the intake straight to the fuel lines. no T splitting here.
no vacuum orbb. again, no T splitting, it goes straight to the cruise control.
we also changed the heater control valve ( the thing that diverts water to the heater core )
now the second I move the slider from off to vents-heater-defrost. the car WILL stall, ( sometimes with an exhaustbackfire )even when I would rev it, the second I touch the panel, it will die.
anyone here got an idea ?
also tried to deattach line that goes in into the T fitting with check valve.
I attached it so that I had ( on the back of the manifold )
1)map sensor
2) brake assist
4)cruise control
the otther line on T-fitting I plugged off.
yet aagin, the second I touch the controls the car dies....
Old Apr 13, 2012 | 07:59 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: vacuum leak
Have you looked up under dash I think there is some vacuum controls up in there that go bad. These control the heater vent door I believe.
Old Apr 13, 2012 | 09:48 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: vacuum leak
I hate to say it, but you really do have to start at the source on something like that...you will have to locate the solenoid to the door directing air flow, and go from there, which probably means pulling the dash out, and possibly pulling the wiring harness apart as I seem to remember some of the vac lines going through the wire harness conduit.
Old Apr 14, 2012 | 07:17 AM
Edwardgp's Avatar
Engine: 454-350
Re: vacuum leak
I was trying to be gentle but Timmie you might have a project ahead of you.
Old Apr 14, 2012 | 09:05 AM
Engine: 3.8, 3.4
Re: vacuum leak
And unfortunately since it immediately stalls, he can't just go around spraying a flammable substance around vacuum line till the engine speed changes, and I am reasonably certain he doesn't own a smoke machine for finding vac leaks, lol.
Old Apr 14, 2012 | 09:16 AM
Edwardgp's Avatar
Engine: 454-350
Re: vacuum leak
Well Timmie keep us informed and since summer is coming up you will have time to get a manual to help along with asking questions here on this forum.
Old Apr 14, 2012 | 06:00 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: vacuum leak
Heater controls use a completely separate harness, coming out of the passenger's compartment to the lower right of the heater box (engine side of the box if you're right-hand drive). ALL wiring and vacuum stuff is in this harness.
Does anything happen when you move the temp control slider from cold to hot (the temp control slider controls flow of heat in and out of the core via the control valve via a secondary vacuum director)?
Disconnect the vacuum lines for the HVAC controls and switch them. May be backwards.
Old Apr 14, 2012 | 06:51 PM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Re: vacuum leak
I think i'm gonna start with something basic and install an orbb of power
then I check what its gonna do with it attached.
starting to think its gonna be somekind of combination of.
no orbb ( less vacuum reservoir ) + less vacuum total due to camshaft = almost no vacuum to keep engine happy..
Old Apr 19, 2012 | 07:17 AM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Re: vacuum leak
installed the reservoir, and the engine doesn't stall right away anymore. ( also put the timing right )
but yet still when I move the heater control switch to a position that isn't airco or OFF, ( Vent -heater-defrost ).
it sometimes starts surging.
so I think I have vacuum problem behind the HVAC.
btw, how do you know when the hvac is bad.
I mean, I hear hissing when I move the switch to different positions, ( specially if you put it into defrost. you could really hear het gow phhheww. ( always had that )
even if you set the contact off, and you moved the switch, you could hear it. when you moved the slider from off or vents, or heater to defrost.
I never heard it when it was 1 position for a while
Old Apr 19, 2012 | 10:00 AM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Re: vacuum leak
what do you mean with that ?
Old Apr 19, 2012 | 02:48 PM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Re: vacuum leak
looks like it has nothing to do with vacuum.
since the engine also stalls when the fan comes up.
so I checked something else, and I checked I could change the heater controls when I disconnected the blower fan.
and yes, it works.
so actualy my engine starts doing freaky stuff when something big uses power. I think its probably because I installed the new heads ( painted )
and that now all the electrical **** connected to the heads don't get enough ground.
So I'm probably gonna put in some more ground from the back of the block to the chassis. that will do the trick I guess.
Old Apr 19, 2012 | 04:28 PM
Edwardgp's Avatar
Engine: 454-350
Re: vacuum leak
Yes sir I made my own grounding straps.
Old Apr 19, 2012 | 04:33 PM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Re: vacuum leak
edwardgp ?
you keep saying strange things....
Old Apr 19, 2012 | 05:18 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: vacuum leak
The HVAC vacuum control switch is on the back of the control head and is held in by 2 screws. From the sounds of it, it's either a vacuum motor line gone bad or the control switch. Go to a junkyard and grab one. Be warned... You need to take yours with you and make sure it will bolt up right. I know from experience that one from a Blazer (or was it a Caddy? IDR) won't fit our control head.
:edit: And what edward is referring to is the fact that it seems you need some new grounds to your engine. Start with the braided strap at the back of the passenger's side. I put an 8 gauge wire on there to make sure. Then, disconnect the battery and clean the crap out of the block and terminal where the negative batt terminal bolts to the engine. Do the same for the little ground next to the battery as well. Better yet, do the same for EVERY ground you see.
Old Apr 19, 2012 | 05:36 PM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Re: vacuum leak
look where I'm located, I only know 3 USA junkyards, 1 in belgium 2 in holland, and both ask ridiculus prices.
think about 3 dollars less then what you pay for a new part at the dealer....
I know 1 guy that asked 128 for a dodge taillight that costed 140 at the dealer NEW.
I already thought about that grounding.
gonna do that tomorrow.
Old Apr 19, 2012 | 05:39 PM
Edwardgp's Avatar
Engine: 454-350
Re: vacuum leak
Maverick You said it much better than I could have. Yes made my own grounding straps soldered ends on the wires and I was good to go.
Engine: 2.7L V6
Axle/Gears: 4.41
Re: vacuum leak
Well, there's always eBay. Sorry I can't help more with that as I need to keep mine...
FormulasOnly
Jul 23, 2018 08:47 AM
bbsr72
Apr 2, 2016 09:12 AM
jrdturbo
Mar 31, 2016 02:58 PM
86maro_252
Oct 10, 2015 06:52 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
