Whats the name of this piece?
Old May 3, 2012 | 07:04 PM
Pointform's Avatar
Does anybody know what the name is for this piece. It desintigrated and i have to replace it. The engine is a 2,8l mpfi.
Attached Thumbnails Whats the name of this piece?-img-20120430-00070.jpg   Whats the name of this piece?-img-20120503-00072.jpg
Old May 3, 2012 | 07:11 PM
project89's Avatar
Re: Whats the name of this piece?
thats just a heater hose pipe unfortunatly u cant buy those anymore.
those 2 pipes that come off the big one run up to the throttle body to heat the bottom of it so the throttle dont stick closed in the winter
unless u live were its like 15* or lower in the winter u dont have to hook those up
what u can do is goto the parts store and get a barbed heater hose fitting, it will have pipe threads on one side and a barbed fitting for clamping a hose on the other end.
to use it just remove the fitting out of the intake and replace it with the new fitting and get a longer hose to connect from there to the heater core up on the firewall
Old May 5, 2012 | 04:44 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
That is pretty much what I did, its 1/2" pipe thread fitting if memory serves, I am sure about the pipe thread but don't take my recollection for perfect as far as what size it was.
Old May 7, 2012 | 01:45 PM
Pointform's Avatar
And any part store would have this?
Old May 7, 2012 | 02:00 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
I did the same thing that project89 is saying. Got the parts at napa. Cost very little.
Old May 9, 2012 | 07:05 PM
Pointform's Avatar
This is how it turned out.
Old May 9, 2012 | 07:15 PM
project89's Avatar
yup thats the normal repair, if the hose turns to tight u can goto the hardware store and get a 2 inch 1/2inch pipe nipple that will screw into the intake then u screw a 90 fitting on the end of that, then u screw the brass hose barb onto that and reconect the hose.
looks liek u dont have an issue with the hose collapsing though so u should be good just the way u have it
Old May 9, 2012 | 08:03 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Looks just like mine although I reused a 90 degree bend hose
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
LC2 TECH
Oct 13, 2015 11:53 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
RS Reaper
Sep 27, 2015 07:04 PM
