beefing up the 2.8l
Old May 16, 2012 | 01:50 AM
89rs2.8l's Avatar
Car: 1999 Trans Am GTA
beefing up the 2.8l
I am new to the forums and I just bout a 89 firebird 5spd v62.8l I was wondering how much hp boost i would get if i installed this http://www.summitracing.com/parts/HY...n/?prefilter=1
also installing headers on the 2.8l would it make a difference?
Old May 16, 2012 | 02:25 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: beefing up the 2.8l
buying a bad of potatochips is a better deal.
Old May 16, 2012 | 11:28 PM
darion45405's Avatar
headers will definitely make a difference. just make sure to get a high flow cat or you might burn it up.
Old May 18, 2012 | 02:00 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Ditto on no to the chip, if I recall all they do is change when the fans come on and some other little thing that doesn't do much of anything. The headers should be a 5-8hp gain, 5 or so with stock exhaust probably, if you couple it with a mandrel bent 2.5" catback and high flow cat, probably 8-12hp gain total.
92projectcamaro
Dec 8, 2015 12:25 AM
bplessy
Sep 30, 2015 12:14 PM
Zell1luk
Sep 29, 2015 10:36 AM
75bike
Sep 20, 2015 09:37 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
