1991 3.1 Stalling.
Old May 29, 2012 | 08:58 PM
Froddoyo's Avatar
Car: 91' Camaro RS T-top
Engine: 3.1 V6
1991 3.1 Stalling.
So in the last Two weeks my car has bin stalling.
When in Park. The car will either idle at 1800 RPM after I Rev it a bit, it will stick at 1800 RPM for as long as the car runs. When I hit the brake while still in park. The cars idle drops to about 900, or 400 then quickly stalls. ONCE IN A WHILE- the car will seem to run fine.. 75% of the time my car acts up and does all these problems.
While Reversing the car stalls VERY easily, a slight touch of the brake and the car instantly stalls. which means I have to rip quickly when in parking lots which is somewhat hard.
While in drive the car will tend to keep up better but will sometimes stall when stopping. If I Very slightly brake to stop, barely braking at all it will not stall.
I have a feeling it is the throttle body. Today me and my father lubricated the moving areas on the throttle body and the car seems to run better. Not sure if this is 25% luck or if the throttle body is the case.
I do infact work at a Autobody shop. I am just not a motor working type of person.
Old May 29, 2012 | 10:15 PM
project89's Avatar
Re: 1991 3.1 Stalling.
have u recently kiled the battery or had the battery unhooked for any reason
Old May 30, 2012 | 07:32 PM
Froddoyo's Avatar
Engine: 3.1 V6
Yes. to replace the alternator.
Old May 30, 2012 | 07:39 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
sounds like you need todo the idle relearn.
Old May 30, 2012 | 07:44 PM
Froddoyo's Avatar
Engine: 3.1 V6
Would that be these steps?
http://www.v6z24.com/howto/idlerelearn
Old May 30, 2012 | 08:14 PM
project89's Avatar
that looks right , i know theres a post on here somewere on how to redo it.
more then likley thats all u will need to do, anytime the battery dies or u disconect it in a 3.1 car u will have stalling issues rough idle until the idle relearn is done
u dotn have to do that procedure the ecm will do it on its own while ur driving the car around but it takes a long time. doing it the way in thos eposts gets it over and done with fast
be sure to unplug the battery for 5 minutes before doing it
Old May 30, 2012 | 08:24 PM
Froddoyo's Avatar
Engine: 3.1 V6
Done. I unplugged the battery for like 10 minutes. did the procedure 100% correct. And it seems to have worked. I'll know for sure if it does good gettin me to school tomorow
Old May 30, 2012 | 08:27 PM
project89's Avatar
im sure it will fix it specially if it wa sfine before u unhooked the battery
gota love when its something simple and it dont cost u anything to fix it
Old May 31, 2012 | 11:02 PM
Froddoyo's Avatar
Engine: 3.1 V6
Resolved but unresolved.
So. I found out a panel under my dash was not perfectly fit in, couldnt manage to make it fit either\. causing the panel to push the throttle more than needed, when I hit the brake, It caused the panel to slide up releasing the panel, the car was learning to idle with the panel down. So it caused it to stall when the panel was up. So I used a heat gun, then notched a small spot so the throttle did not interfere with the panel. I made the car relearn again. But I started it. Car kept stalling unless slight gas was applied. when I went home from work I had to ride the gas slightly as I braked. But on the highway car drove perfectly normal. When I got home the all idle problems went away. later that night I started it again, couldnt idle on itself
Seems that when the car runs and drives for about 4 minutes. It will idle proper. but just after starting it and letting go of the gas. It will die. The car works for me but it bothers me that I will have to manually warm the car up every time I go to drive it.
Linson
Oct 24, 2025 02:00 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
Macchinist
Oct 2, 2015 02:55 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
