Car CONSTANTLY stalling after replacing iac valve
Old Jun 12, 2012 | 06:46 PM
Froddoyo's Avatar
Car: 91' Camaro RS T-top
Engine: 3.1 V6
So Today, I replaced my Idle Air control Valve. Because my car would be idling funny when first started up.
this has bin an issue with my car. 2 weeks after I bought. this car is starting to make me VERY ANGRY. I replaced the IAC valve. and now. the car cant barely drive without mashing the gas. I am almost ready to set this thing on fire and say goodbye to it. And get it the f**k out of my life. Does nayone know why this would be after replacing it.
Old Jun 13, 2012 | 07:14 AM
zombienerd's Avatar
Car: 1982 Firebird Base
Engine: 2.8L V6
Axle/Gears: Stock
Re: Car CONSTANTLY stalling after replacing iac valve
I'm not an expert on the fuel injection on these cars, but I'd look at the air-flow sensor, (MAP/MAF). Horribly rough idle can point in that direction.
I'd also check your timing.
Old Jun 13, 2012 | 05:40 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
You probably didn't reset the ECM and go through the idle relearn procedure after replacing the IAC. Or test for vacuum leaks. And it probably should have a tune up if you haven't done that yet, either.
Old Jun 13, 2012 | 07:29 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Try what mav. said. I replaced my IAC before and didnt do the relearn.....and it actually made it worse. Once I did the relearn, my problems went away.
Also mines a automatic, I know those need that relearn proceedure.
Old Jun 14, 2012 | 10:33 PM
Froddoyo's Avatar
Engine: 3.1 V6
Yea. I tried the relearn 10 minutes after posting this. Worked. Car idles fine. but NOW. 3 days after car running fine. car seems to shake/rumble (idle kinda studders) quite a bit. when hitting 1750+ rpm when goin 30k or lower. I'm guessing that might be a timing issue.
Old Jun 14, 2012 | 10:36 PM
conlinj's Avatar
checked for vacuum leaks?
Old Jun 16, 2012 | 08:19 PM
Froddoyo's Avatar
Engine: 3.1 V6
No. I'll have that checked over though.
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
NBrehm
Aug 25, 2015 11:49 PM
TreDeClaw
Aug 14, 2015 06:58 PM
drathaar907
Aug 6, 2015 04:20 PM
