Timing chain fitment
Old Jul 11, 2012 | 02:31 PM
projectfirebird's Avatar
Car: 92 Firebird
Engine: 3.1 MPFI
This friday, I'm going to order a new cam and set of lifters for my 3.1 v6, and my question is if this 2.8 timing chain would fit my car:
http://www.summitracing.com/parts/CCA-3030/
Part #CCA-3030
I searched this site to see if I can. I know the 2.8 and the 3.1 have very few differences, I just want to make sure the timing chain length isn't one of them.
Thanks.
Old Jul 11, 2012 | 03:02 PM
project89's Avatar
Re: Timing chain fitment
that chain will fit, but thats not the part u want.
thats only part of replacing the timing set, u also want new gears and chain guide
Old Jul 11, 2012 | 03:05 PM
project89's Avatar
this is what u want
http://www.summitracing.com/parts/SLP-KT3-368S/
i cant recall if my timing sets came with the chain guide or i had to buy them sepratly
Old Jul 11, 2012 | 05:25 PM
Car: 92 Firebird
Engine: 3.1 MPFI
Ok thank you. And also, do I really have to lift the engine and remove the oil pan like the chilton's manual says? I guess I'd just have to look at it when I get to it.
Old Jul 11, 2012 | 05:39 PM
project89's Avatar
i know for a fact with the 2.8 u dont have to lift the engine, u drop the pan and rotate the crank and it slides back a lil bit, then u turn the crank and it will drop back some more and finally out .
the 3.1's longer stroke on the crankshaft may prevent that
Old Jul 11, 2012 | 06:29 PM
Car: 92 Firebird
Engine: 3.1 MPFI
Thank you again, project 89. When all the parts I need come in, I will start a build thread. My engine is already mostly apart, and my goal is to have it set to where all I have to do is put the new parts in!
Old Jul 12, 2012 | 08:36 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
No need to touch the pan to take the timing cover off. Even the FSM states to remove the oil pan to remove the front cover, not sure why.
RBob.
Vintageracer
Jan 10, 2020 05:33 PM
kah992
Aug 19, 2015 02:55 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
