And so it Begins... (3.4 swap)
Old Jul 25, 2012 | 06:44 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Picked up a nice 88k mile 95 3.4 for my beloved Camaro. Going to get to work this weekend on the swap, and have her running before Monday. Payed $200 cash for it. GOnna do all gaskets, new water pump, dist cap/rotor, plugs, plug wires, coil, full tune up really. Few pics of the motor.
Working motor, full harness, not like I need it. I just wanted the block and heads. Thinking of putting my Comp Cams 260H cam in it. Not sure yet. And a pic of my baby its going into:
Don't mind those nasty turn signals, I put in a brand new GM NOS set. More pics to come.
Old Jul 25, 2012 | 06:51 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Re: And so it Begins...
Let us know how it goes!
Old Jul 25, 2012 | 06:52 PM
project89's Avatar
cam it while ur in there
Old Jul 25, 2012 | 06:53 PM
Car: 1989 Camaro RS
Engine: LH6
Should I just get a new cam, and go bigger? I don't know much about the cam I have, all I know its a 260H and its been in the motor a long time.
Old Jul 25, 2012 | 07:10 PM
project89's Avatar
ahh theres already a 260 cam in the motor?
i wouldnt go bigger without porting the heads, and if that motor has a 260 cam talk to fast eddi and se eif he will sell u a tune for that engine
Old Jul 25, 2012 | 07:44 PM
Car: 1989 Camaro RS
Engine: LH6
That's whats in my 2.8 now. I was gonna pull it from the 2.8 and put in the 3.4.
Another question, 2.8 heads on a 3.4, higher compression = more power? Or just a waste of time?
Old Jul 25, 2012 | 07:56 PM
project89's Avatar
yeah put the cam from the 2.8 in the 3.4, no the 2.8/3.1/3.4 heads are all the same,
when u swap the cam over u have to make sure each lifter goes back in the spot it came out of or u will wipe out the cam
Old Jul 25, 2012 | 08:22 PM
Car: 1989 Camaro RS
Engine: LH6
Should I use the valve springs, lifters. ect from the 2.8? I'm assuming the valve springs on the 2.8 are aftermarket to go with the cam.
Old Jul 25, 2012 | 09:25 PM
project89's Avatar
u will have to pull the heads to change the valve springs
Old Jul 26, 2012 | 06:30 AM
Car: 1989 Camaro RS
Engine: LH6
Yeah, I'm just wondering if the stock springs will be fine with the cam.
Old Jul 28, 2012 | 08:40 AM
Car: 1989 Camaro RS
Engine: LH6
Well, I've gotten the 3.4 torn down for the most part. Just a few more things to take off. Gonna prep the 2.8 to come out. Hopefully will have it out later today. Will take pics.
Old Jul 28, 2012 | 06:24 PM
Car: 1989 Camaro RS
Engine: LH6
Good progress today. 2.8 is almost out, and 3.4 is ready to get put together. Gonna have a buddy come by tomorrow to put my cam in for me. Here's some pics from today:
3.4:
New parts:
And a couple random shots.
2.8 is about 6 or 7 bolts from coming out. I'm getting close.
File Type: jpg
Old Jul 28, 2012 | 07:03 PM
project89's Avatar
make damn sure when u move the cam from the 2.8 to the 3.4 that each lifter goes back in the same place i.e if the lifter comes out of the front hole on the driverside of the motor on the 2.8, it has to go in the same hole on the 3.4.
failure to do so will result in a wiped cam and it can very well destroy the 3.4
do u have headgaskets?if so pull the heads and do some basic portwork
dont forgoet to use the oilpan and front cover off ur 2.8 on the 3.4
Old Jul 28, 2012 | 07:06 PM
project89's Avatar
almost forgot can u take some pics of the lower 3.4 intake and the 2.8 lower intake, want to see if theres any real differences in them ive never had a 3.4 lower in my own hands to compare
Old Jul 28, 2012 | 07:29 PM
Car: 1989 Camaro RS
Engine: LH6
Already have the timing cover pulled, swapping that as well. No head gaskets, I would have had to wait till Monday, and I need to get the motor in this weekend.
Will do.
Old Aug 4, 2012 | 02:04 PM
Car: 1989 Camaro RS
Engine: LH6
Good progress today, motor won't go in for this reason:
Flex plate is done for. That piece fell out shortly after this pic.
But here's the bottom of the 3.4. Looks nice I think.
I'll have my 1.6 roller rockers up for sale soon, not too sure what to ask for them.
Old Oct 4, 2012 | 02:31 PM
Car: 1989 Camaro RS
Engine: LH6
Fired it and it runs good now, just needs final timing adjustments, and I need to figure out a new electric fan management system. I couldn't get the plug out of the passenger side head for the temp sensor. Any ideas?
Old Oct 4, 2012 | 09:43 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I'm assuming you mean the backup fan switch by the lifting eye... It's not needed. I couldn't get the plug out of my 3.1 either and left the wire loose, never had any problems with the radiator fan. It's the one on the driver's side front you REALLY should worry about.
Old Oct 4, 2012 | 10:10 PM
Car: 1989 Camaro RS
Engine: LH6
That's good to know then. That one is fine, but I may get a new sensor just because. Car has hit 220 while at idle for a long time and fan hasn't kicked on. So I'll double check all my connections.
I really need to get a more reliable second car so I can turbo this thing. Mercedes just doesn't cut it, too much to fail, and gas mileage is like 5-8 MPG.
Old Oct 4, 2012 | 10:32 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: And so it Begins... (3.4 swap)
Stock fan turn on temp is 235*...
Old Oct 4, 2012 | 10:37 PM
Car: 1989 Camaro RS
Engine: LH6
That's good info to know as well, I always thought it came on before that.
Old Oct 6, 2012 | 11:39 AM
XxXChrisGXxX's Avatar
Car: 1987 Chevrolet Camaro
Engine: 2.8L V6 MPFI
Axle/Gears: 10 Bolt
Where do you find these engines so cheap...grrr
Want to build one in my basement for when I need it lol.
Old Oct 6, 2012 | 01:34 PM
Car: 1989 Camaro RS
Engine: LH6
I drove an hour to get it, guy had it because he works at LKQ. He had it for sale for months and finally had it listed for $200.
Drove the car down the street today, boy have I missed it. I got a new TV cable ordered, some more timing adjustments, gotta fix a exhaust leak, need I new speedo gear for the trans, register and insure, and I'm set.
Old Oct 6, 2012 | 01:35 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
That may be what the "all hope is nearly lost" fan temp switch setting, but the normal operatonal fan temp is much lower, around 190*F. Setting a normal operation fan on temp to 235*F would cause many problems.
Old Oct 6, 2012 | 01:37 PM
Car: 1989 Camaro RS
Engine: LH6
I've noticed that since first start up the fan came on very late, but once it was needed again it came on at the appropriate time, I'm guessing because the ECM is relearning everything. That or I'm crazy.
Old Oct 7, 2012 | 04:02 PM
Car: 1989 Camaro RS
Engine: LH6
Drove it some more today, had a oil leak at the filter housing, fixed it, installed a new fuel filter, and adjusted the timing some more and I'm set. I insured the car, just gotta get it registered. I need to advance the timing a little more, add a quart of oil, and a little but of trans fluid and she's good to go.
I do need the piece that goes in the rear of the trans for the cable driven speedo, if somebody has one, I'd love to buy it as mine is broken. Speedo works, but the threads are done.
Once I get another car to replace the Mercedes, I'll put my 60MM on it.
Old Oct 7, 2012 | 06:47 PM
Engine: 2.7L V6
Axle/Gears: 4.41
And when was the last time you looked at a stock PROM calibration? Says so right in the FSM. And since the stock thermostat doesn't open until 195*F, that would be kind of idiotic...
RubberDucky, I have 2 of those bullets if you need one. One has a metal gear shaft in it and the other has no gear shaft in it (nylon gear with attached shaft).
Old Oct 7, 2012 | 07:04 PM
Car: 1989 Camaro RS
Engine: LH6
I need the one with the gear, and the shaft for the cable. I got one off a 85 V6 car with a T5 thinking they would be the same, they were not. Lol.
I would be VERY suspect of a calibration that shows anything above 200*F for fan on temp. Very likely the calculation is wrong in the XDF. Last I checked the (stock) T-stat opened at 190*, you know, it's not like I haven't been around these engines for many years.
235*F engine temp would cause some serious damage if it was ran there all the time, oil would break down down quickly, and cause higher than necessary cylinder temps, that would be difficult to keep detonation at bay.
Old Oct 7, 2012 | 07:05 PM
Axle/Gears: 10 Bolt
What kind of mileage did your 2.8 have? Doesn't make that much sense for an extra 20 HP with the 3.4, unless your 2.8 was high mileage. Guess it is preference.
My 2.8 has 84K, was going to build a 3.4 for when the 2.8 hits 200K or so. It's my DD so...that wont be long.
Old Oct 7, 2012 | 07:08 PM
Car: 1989 Camaro RS
Engine: LH6
What kind of mileage did your 2.8 have? Doesn't make that much sense for an extra 20 HP with the 3.4 no?
Not exactly sure what it had, but it was 175k+. It had a cam and roller rockers, that I was going to sell, but I dropped the box with the lifters and all on it, so at that point it was worthless.
Old Oct 7, 2012 | 07:11 PM
Axle/Gears: 10 Bolt
Sounds reasonable, I'll be doing the same soon enough. Hoping to get 100-200K more out of my 2.8 it's been taken care of.
In the meantime going to look for a cheap 3.4 for a basement build..woot
Old Oct 7, 2012 | 07:13 PM
Car: 1989 Camaro RS
Engine: LH6
These motors will last for ever if taken care of, last one, obviously wasn't.
I believe this 3.4 has been rebuilt in its life, it had a tag stuck to it saying warranty void if removed, which, I know wasn't a GM thing.
Old Oct 7, 2012 | 07:17 PM
Engine: 2.7L V6
Axle/Gears: 4.41
UGH... 87 FSM, Chart C-12, Coolant Fan Control Circuit, 2.8L "F" Series, Circuit Description:
"The ECM grounds CKT 335 (relay control circuit) when coolant temp is over 106*C (223*F), and/or when A/C has been requested and the fan control switch opens with A/C system pressure over about 200 PSI. Once the ECM turns the relay "on", it will keep the relay "on" for a minimum of 30 seconds or until the vehicle speed reaches 70 MPH."
I don't think the engineers who wrote the book lied.
RubberDucky, I do NOT have a gear for either bullet. The gear that was on the metal shaft is currently on the end of my VSS, and the other one is gone.
Old Oct 7, 2012 | 07:22 PM
Car: 1989 Camaro RS
Engine: LH6
Meh, no worries. Speedo works for now, just isn't perfect. I'll find one.
Old Oct 9, 2012 | 02:11 PM
Car: 1989 Camaro RS
Engine: LH6
Registered the car, and will be driving it when I get home from work. Pretty excited, now I need a T-5 and my 60mm on it. Lol.
Old Oct 9, 2012 | 02:24 PM
89JunkerRS's Avatar
Car: '89 Camaro RS
Axle/Gears: 3.42, Open
pretty cool, I had a '93 camaro with the 3.4, It moved itself around pretty good and was great on gas, I just wasn't a fan of the 4th gen body
I'd love to have a nice v6 third gen like yours for a daily driver
Old Oct 9, 2012 | 05:52 PM
Car: 1989 Camaro RS
Engine: LH6
Mine started out faded, with a blown motor, bought it for $900 in 09. And its as you see it today, some $2000+ later. Lol.
Its easy to find a good car to fix up.
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
92projectcamaro
Aug 6, 2015 01:20 PM
