Lifters...
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Lifters...
As most of us know, V8 lifters are not compatible with 60*V6 lifters, but you can take the springs out of the V8 lifters and put them in the 60* lifters for better performance.
I am in the process of trying to retrofit the LS7 Lifter mechanisms into the 60* body. so far, I've got a set of 60* lifters, and the LS7 lifters in order with USA Performance, here in Pensacola.
I'll keep everyone posted as to what happens!
Re: Lifters...
i could have saved u a whole lot of money and told u how to modify the lifters like i did in my car.witht he mods i have done we can turn 8k rpms without lifter pump up or valve float witht he right valve springs
Re: Lifters...
flat tap or roller? I'm referring to the 3x00 roller lifters.
Re: Lifters...
ahhh i modded the hyd flat tap lifters, u could prolly mod the roller lifters the same way though.
basically the way i modded mine makes them sort of a hybrid solid/hyd lifter
Re: Lifters...
i know i posted it here somewere but i cant find it, even had pictures.
basically we cut down the springs and shimmed the hell out of the spring/pluger with tiny heat treated washers we left the plunger with only .015 of travel i belive but i need to find the thread to be sure
let me check my photobucket and see if the pictures are in there
Re: Lifters...
I took 3 lifters apart today,
1 3400 lifter
1 "LS7" lifter
and
1 Comp Magnum SBC Lifter.
The comp and the LS7 were nearly identical. I also found that if you machined the piston on the V8 lifters down a little bit, you could install them in the 60* and turn them into solid lifters.
Pics tomorrow
1 3400 lifter
1 "LS7" lifter
and
Pics tomorrow
Re: Lifters...
a little later than tomorrow, but here you go
Left to right, Comp cams "magnum" "LS7" and stock 60*
aaron7
Sep 7, 2014 07:24 AM
