2.8l engine more power??
Old Aug 17, 2012 | 02:55 PM
Na8eR91's Avatar
Car: 1990 camaro rs
Engine: 2.8
Transmission: TH400
ok, i just bought my 1990 camaro rs that has 80xxx miles for $350 and i replaced the timing chain and gears and flushed out all of the fluids. It is a 5-speed with a posi rear end. i put flowmasters on it, and i built a custom cai and an MSD ignition but im still lacking the power that i want. I like the v6's and dont really want to do a swap. Any help i need more power and i dont know what to do next
Old Aug 17, 2012 | 04:01 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: 2.8l engine more power??
You can get headers from Pace-setter. Then you're into porting etc. etc. Or go 3.1 or 3.4.
Old Aug 17, 2012 | 05:21 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Agreed:
Headers
Port and polish the heads(which is basically free)
Delta 260 or 272 in your case since its a stick, Cam
Tune the car with moates stuff and your golden.
Old Aug 17, 2012 | 05:59 PM
Guest
Guest
Posts: n/a
Turbo. Fairly painless and most turbo v6's on here will give the mild v8's a run for their money
Old Aug 17, 2012 | 06:29 PM
project89's Avatar
i agree on the turbo, theres a guy selling all the big parts needed to turbo a car in the classifieds section for 320 bucks
Old Aug 17, 2012 | 11:15 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Old Aug 18, 2012 | 01:57 AM
Na8eR91's Avatar
Car: 1990 camaro rs
Engine: 2.8
Transmission: TH400
I was looking for pacesetter long tube headers but i can seem to find them, and by way of a turbo what am i looking at for a PSI i have put turbos in cars before but never on a 3rd gen is their going to be a lot of fab work or is it a bolt on and should i put a different clutch in it as well..............i have 3.73 rear gears should i swap them out for something different or leave them as they are?????
Old Aug 18, 2012 | 08:22 AM
fasteddi's Avatar
Car: 1991 Camaro RS
3.73's are great gears Id personally leave them as is. If you have a manual car and you turbo the car in time, youll need to upgrade you clutch as I know it will eat through that clutch in no time.
For the turboed PSI I run 14psi most of the time anymore and its a hellish ride. Even though I've had my share of problems but it is still worth the time to work on it to have such a fun riding car.
Theres a good amount of fab work required to turbo the car, mainly the charge piping and the exhaust piping. With a welder, some piping, and creativity you can get it done quite easy.KI
Old Aug 18, 2012 | 09:50 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
A 90 Camaro with a 2.8? My 90 Firebird had a speed density 3.1 from the factory. Don't you have a 3.1?
Anyway, if you are stuck on the V6, you should start with a 3.4 from a 4th gen, or the HT 3.4 crate engine. My local pick your part yard has 4 of these 4th gen setups here, I just don't want to do it.
Here's the crate engine:
http://www.jegs.com/p/GM-Performance...61682/10002/-1
Anyway, you do that first to get the largest engine under your hood with the smallest amount of modification required. Next, you have a fork in the road. Iron heads or 3x00 front wheel drive top end swap.
I'd say start looking for the 3.4 now. I wouldn't buy the headers yet, because once you search these forums a bunch you're going to change your mind a bunch on whether you want that top end swap or not.
Good luck!
Old Aug 18, 2012 | 09:57 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Good point and it says he has a TH400 trans in his sig not a 700R4(4L60). Mabey he swaped it but its very doubtful.
Old Aug 18, 2012 | 10:05 PM
Na8eR91's Avatar
Car: 1990 camaro rs
Engine: 2.8
Transmission: TH400
The guy that had it before i did swaped the TH400 in and yea it a 2.8, ive found turbo kits and i ordered one but should i hold off on the headers and leave the flowmasters on it and what should i put in for the clutch?? or forget all of it and just go for the 3.4 swap??
Old Aug 18, 2012 | 10:09 PM
haisud's Avatar
can you give link to this turbo kit?
Old Aug 18, 2012 | 10:19 PM
project89's Avatar
u do not have a th400 behind ur v6 for one it dosent bolt up without an adapter plate and other mods
Old Aug 18, 2012 | 11:47 PM
fasteddi's Avatar
Car: 1991 Camaro RS
OK so you have a auto trans?? I would be willing to bet it is a 700R4 (4L60) And if so you dont need to worrie about a clutch as you dont have one, you have a torque converter in its place on a auto.
What turbo kit did you buy??? If you did theres no sence in buying headers and youll wana tear off the mufflers anyways in time if you anything like me. 2 months now and ive been running nothing but a goold ole turbo to quiet it down.
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
InfinityShade
Aug 22, 2015 08:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
