Hypertech Thermo Master Cal-Pac Power Chip - Stage 2
Old Aug 23, 2012 | 04:27 PM
sonu1975's Avatar
I have a stock V6 1991 camaro and I am thinking to change my stock PROM to Hypertech Thermo Master Cal-Pac Power Chip - Stage 2.
Do I need to do anything before or after I have changed from stock PROM ?
How many hp do you get ? Is it worth doing it or ?
Thanks for help. Need to fix up my rid a bit
Old Aug 23, 2012 | 04:43 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Hypertech Thermo Master Cal-Pac Power Chip - Stage 2
No it is not worth doing at all. Those things cost to much and realistically you could get the basic equiptment to burn your own chips yourself for close to what those things cost.
On the otherhand, theres nothing you have to do else then I would add a lower t-stat (180*) if you get one of those hyper chips. You would mabey gain 5-10Hp on a good good day, and thats being generous. IMO
Old Aug 23, 2012 | 04:53 PM
sonu1975's Avatar
Thanks for the info fasteddi.
You are right not worth paying that much for 5-10Hp
Old Aug 23, 2012 | 06:15 PM
fasteddi's Avatar
Car: 1991 Camaro RS
What do they cost anymore anyway??? Like $150 bucks or so?? I got one way back in the day for a different car and it really didn't do much at all in the 1/4 mile when racing it.
The best things money wise to add HP is A cam, Exhaust(be it headers, and so on), rear end gears, and stuff like that.
WEIGHT REDUCTION is a good mod.
Then it all depends what you can personally do as in a cam, porting the heads/intakes, exc. There are many ways to make your car fast it just matters what you want and all comes down to $$ and what you can do.
formula1lle
Jan 29, 2016 10:56 AM
bamaboy0323
Sep 3, 2015 06:07 AM
NBrehm
Aug 25, 2015 11:49 PM
sailtexas186548
Aug 24, 2015 10:11 PM
86White_T/A305
Aug 17, 2015 12:16 AM
