2.8l stock y pipe size
Old Sep 4, 2012 | 07:35 PM
91camrors's Avatar
1983 camaro 2.8l
what size is the stock y pipe? i want to cut the y pipe and make duals but wondered what size pipe ill need
Old Sep 4, 2012 | 08:15 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: 2.8l stock y pipe size
You're better off getting flanges from NAPA or somewhere and starting fresh... The stock y-pipe is actually a pipe inside a pipe, and it's not very strong.
Old Sep 4, 2012 | 08:22 PM
project89's Avatar
mav is right its a pipe inside a pipe, its done that way to insulate the heat from the oil pan , if ur going to do dual ex dont go any larger then 2 inch , anything bigger then that will hurt low rpm performance and just make the thing loud.
hell dual 1.75 would be just fine
Old Sep 4, 2012 | 08:32 PM
91camrors's Avatar
so do 1.75? sweet i live 30 min from summit racing so ill head up there in the morning and get supplies
Old Sep 4, 2012 | 08:34 PM
project89's Avatar
go with 2 inch to be on the safe side , id have to dbl check if dual 1.75 pipe wpould be enough but im pretty sure it is
dual 2 inch would support a ton more power then u could actually make without a turbo or nitrous
besdies the fact that finding decent mufflers for 1.75 will be harder
Old Sep 4, 2012 | 08:41 PM
91camrors's Avatar
well 1.75 glass packs are 13.95. ill do 2 in. i think id like it better
Old Sep 4, 2012 | 08:48 PM
project89's Avatar
dont do glasspacks , they will sound like total crap
if anything get the cherrybomb turbo style mufflers, i used those on my old iroc with dual 2.5 inch pipes and they sounded good, theres enough room to mount them infront of the rear on each side and then u can either do turn downs before the axle or put the tailpipes up and over the rear and out the back like stock
Old Sep 4, 2012 | 09:02 PM
91camrors's Avatar
what about flowmaster chambered welded mufflers?
Old Sep 4, 2012 | 09:09 PM
project89's Avatar
on a v8 yes the v6 is kind of tricky to make it sound good, a v6 witht he regular flowmaster sounds good at idle but really crappy at anything other then idle
i have never heard a v6 with duals and flowmasters so i cant tell u if it would sound decent or not but i have a feeling it would be very raspy
the best sounding mufflers for the v6 i have heard are the magnaflows of dynomax mufflers
morosso makes bullet mufflers that are called spiral flows iirc those are supposed to sound good too
toronto formula
Nov 10, 2015 06:17 AM
bamaboy0323
Sep 3, 2015 06:07 AM
transaero
Aug 31, 2015 01:14 AM
Bstrang6
Aug 26, 2015 11:39 AM
knight72
Aug 10, 2015 09:32 PM
