electric choke problems
Old Sep 11, 2012 | 02:20 PM
91camrors's Avatar
83 2.8l electric choke problems. rochester varajet ii non electronic carb. i think i may have a choke problem. this morning it was about 45* outside. my car would start and run and miss horribly. i think it was the electronic choke. im not 100% on how it functions but is it something i can ard wire to a toggle when i need it to opperate???
Old Sep 12, 2012 | 10:19 AM
ChrisC's Avatar
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
Re: electric choke problems
The choke needs to be hooked up to a 12 v 'key on' source of power. Just run power directly to a spot in your fuse box, don't even bother with a toggle switch.
The way it works is picture the choke coil as a spring. When the choke coil is heated, it tightens. Electric chokes use a current to heat itself to a certain temperature and when it reaches that temperature the choke comes off.
toones
Jan 6, 2016 06:00 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Ducati900ss
Sep 2, 2015 09:05 AM
86IROC112
Aug 17, 2015 02:00 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
