Odd CLICK & POP in the clutch pedal
Old Jan 9, 2013 | 04:12 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
If you feels this yourself sometime like I did yesterday, you only get 2-3 shifts left before the clutch pedal goes limp, find a safe place to pull off quick.
Thats your clutch pedal rod coming off the pedal under the dash, as I assume with time it slowly rocks it way off the end, been 5-7 years since I had it off last, taken all the time to walk itself off, and went right back on with some effort. Dunno why they don't use a cotter pin or something, just a plastic lock clip.
Old Jan 9, 2013 | 05:13 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Odd CLICK & POP in the clutch pedal
Cut the bushing (cut the retainer tabs off and leave the rest to attach the pedal properly) and find another clip like is on the brake pushrod... They're the same. The clutch will never come apart again until you go to take it apart.
Old Jan 9, 2013 | 06:52 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Great idea,
since it came off 2 more times today, would suck during a speed shift.
But just my luck, 27 years and 230,000 miles later, now that plastic clip wears out
Old Jan 9, 2013 | 09:00 PM
Engine: 2.7L V6
Axle/Gears: 4.41
That is how the clutch was assembled on the 84 I pulled my pedals out of. Unfortunately, something happened to the bushing along the way and I drove without one for 4 years . Luckily, I didn't do too much damage to the pushrod. And yes, there is a bushing in it now (the 88 had the clutch assembly fully installed when I got it).
Old Jan 10, 2013 | 12:52 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
think I could find that clip at autozone???
Like in that odd section on the shelf of Dorman odd bits for cars in packages?
Old Jan 10, 2013 | 01:56 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Well I thought I had one, till I crawled under the dash of my 85 S15 parts car, its brake rod not only uses a cotter pin, a beefy hunk of metal bolts over top of that to further lock it on. Would take a tank to make it come off.
Old Jan 10, 2013 | 04:45 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Ended up at the dealer, will cost $2 and be here next week.
Old Jan 10, 2013 | 05:05 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
used ones on ebay for $10, listed as rare part.
Old Jan 11, 2013 | 12:44 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Well that brake clip does not fit on mine, the depth is wrong, nearly broke my back trying, where it pshes on easy on the brake rod.
used a washer and a 5/16" E-ring
Old Jan 11, 2013 | 08:43 PM
Engine: 2.7L V6
Axle/Gears: 4.41
I probably ought to find my other brake clip and modify mine. It was such a PITA to get that stupid bushing crap pressed into place.
Are you sure that you got the right brake clip? Mine slid on with no issues, and I'm not even sure what year car the pedal set was out of (I got some of the parts from the 84, but the pedal set I ended up using was bought on eBay or somewhere and IDK what year car it came from).
Old Jan 11, 2013 | 11:33 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
No idea guy but I was down there till I about broke in half and it would not go on even with force.
Old Jan 15, 2013 | 09:46 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
So far so good, I did put a blob of clear silicone over it, just onthe off chance it might have walked off, the clip wouldn't go MIA on me.
Will test it further when I get a chance to run against fasteddi as either for the past 13+ years ive just imagined I got a little 2.8 that could or I don't
Old Dec 26, 2013 | 04:07 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Cross-reference this thread: https://www.thirdgen.org/forums/tran...re-1988-a.html
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
camaro1185
Oct 26, 2015 06:51 AM
Denricci22
Sep 18, 2015 09:02 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
