88 2.8 jerks while accelerating and bogs when floored
Old Jan 9, 2013 | 06:21 PM
8928cam's Avatar
Car: 83 CaMarO Z28
Engine: 383 stroker AFR heads 600hp
Transmission: 700r4 stage 3
Axle/Gears: 373 9"
this 2.8 has to slowly accelerate to gain speed if ur punch the pedal it wont go at all just hits a mid level rpm and stays there but idles perfect but if i slowly rev it up it will hit top rpm not if i punch it tho? but once i put load to it it doesnt wanna move im stumped on this ive changed alot of s*** and checked vaccums
thanks guys
Old Jan 9, 2013 | 06:25 PM
Guest
Guest
Posts: n/a
Re: 88 2.8 jerks while accelerating and bogs when floored
Throttle position sensor maybe?
Old Jan 9, 2013 | 06:47 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
lose dizzy, only has to move a hair to goof with ya.
Old Jan 9, 2013 | 07:00 PM
8928cam's Avatar
Car: 83 CaMarO Z28
Axle/Gears: 373 9"
just replaced the dizzy and TPS it did same stuff before and still does..wtf lol
Old Jan 9, 2013 | 07:03 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
make sure its tight, after many many moon mine somehow started movin a hair on its own yr or so back, had to really horse down on it to stay put.
would run great one spot, awful like that the other.
also check tach feed wire on the coil, if someone used a quick connect for a tach, they cut the wires.
Old Jan 9, 2013 | 07:08 PM
8928cam's Avatar
Car: 83 CaMarO Z28
Axle/Gears: 373 9"
ok ill check the tach wires
Old Jan 9, 2013 | 07:20 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I only had like 3 strands left of my coil wire from using one of those quick connects. Same thing happened to my fuel pump.
replacement fuel pumps come with quick connects but they are junk.
Old Jan 9, 2013 | 07:25 PM
8928cam's Avatar
Car: 83 CaMarO Z28
Axle/Gears: 373 9"
i think mine is actually spliced into the wiring behind the tach gauge and should i hard wire fuel pump?
Old Jan 9, 2013 | 07:29 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
New replacement FP come with quick connects, mine burnt away till almost an inch gap that juice had to arc for it to "work" left me stranded one night, sucked. Wires are well connected now.
Old Jan 17, 2013 | 06:07 PM
88camaroscv6's Avatar
Car: 1989 Formula, 1988 Camaro
Engine: Vortec 350 TPI, 2.8 V6
Transmission: 700r4, 700r4
Axle/Gears: 4th Gen 3.43 Posi, 3.43 Open
check fuel pressure
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
LC2 TECH
Oct 13, 2015 11:53 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
