Stupid EGR question
Old Jan 14, 2013 | 05:28 PM
TheEndofanEra's Avatar
Car: 92 Camaro RS, 93 Caprice Classic
Engine: 3.1L V6, 5.0L V8 + 700r4 on both
Transmission: Rebuilt 700r4 in the Camaro
Axle/Gears: Stock with 3.23s ...3.73 later?
Stupid EGR question
Okay guys really dumb question here, is the top half of the EGR valve supposed to be loose, or more like, able to wiggle? I made a quick
how it is now, but I just can't remember if it was that way when I put it on last year, or the year before...
The reason I'm asking is it just tripped a code 32 (which would be the EGR), but it was giving me an abnormally high oil pressure reading just before and during the code. Any ideas?
Old Jan 14, 2013 | 05:51 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Stupid EGR question
No its not suppose to wiggle. Tighten it up if you can.
Old Jan 16, 2013 | 09:57 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Should be a T20 torx bit, IIRC. Use anti-seize on the bolts so you can get it apart again later (for cleaning it out).
Oil pressure reading has nothing to do with EGR, BTW. Our gauges are known to not be the best in terms of accuracy. The V6 should be at about 70 PSI when cold anyways. I would only worry if the gauge either reads extremely low or off the scale (off scale means bad sender, usually).
Old Jan 16, 2013 | 11:06 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I found a bad cat on mine like that, not long after I bought the car. My EGR mount had broken off from the manifold because the cat had plugged. I don't know for how long it was plugged, but long enough for the pressure to break the EGR mount.
Old Jan 17, 2013 | 05:29 PM
ItstillaV6's Avatar
Car: 92 Camaro RS
Engine: 3.1L(191ci) V6
Transmission: 700-R4
Axle/Gears: 3.23:1
Yeah, your EGR is definitely leaking, and you definitely have some loose or broken bolts. The EGR itself may need to be replaced. I know, in Ohio, salvage yards are not allowed to sell used pollution control devices. That may be a federal law. If it is not and the valve itself needs replaced, then try to snag one from a boneyard. EGRs are NOT cheap!
I had the same problem, with my EGR, when I bought it 3 years ago. I had snapped bolts. The EGR, itself, had to be replaced. I used an EGR, from a '91 Lumina FWD opt "LHO". I haven't had a single problem or trouble code, since. i was also working in a boneyard, at the time. The engine i got that valve off of, had 309,000 miles on it. Car had been scrapped, because the trans finally went bad.
Old Jan 17, 2013 | 05:33 PM
ItstillaV6's Avatar
Car: 92 Camaro RS
Axle/Gears: 3.23:1
I also have a thread titled "Problems in the Engine Bay", for the 2.8L and 3.1L engines. You can find it in the V6 area, here. The oil pressure sending units were also another thing, that had a high failure rate. The best way, to see, if your oil pressure is correct, would be to hook up a manual pressure gauge, and test it. Like Maverick said, 70 psi on a cold start. I would say 40 psi at idle, between 45-55 psi, when operating between 1500-2500rpm. I can go home and get the specs, from a Haynes manual, later, and post what they claim.
Old Jan 20, 2013 | 01:46 PM
Thanks everybody, I tightened the torx bolts back down and no more wiggling or codes so it looks good - I'll just have to make sure I check it whenever I do an oil change lol.
Yeah, next time I'll read through the "Problems in the Engine Bay" thread before I post. I was a little panicked, I didn't want to have to replace my new EGR with another new one . And no need for the oil specs, I've got a copy of the service manual (now I just need to learn to use it )
Cleotiz
Jan 6, 2018 08:56 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
camaroken83
Aug 10, 2015 11:35 AM
