Where to buy a thermostat housing?
Old Jan 18, 2013 | 05:52 PM
xMrBadDogx's Avatar
Car: 89 Camaro RS 2.8 V6
Engine: 2.8 MPFI V6
I need to buy one cuz mine is REALLY rusted out, this seems to happen to all the metal pipes on my car that having coolant flowing through them. Is there anyways to prevent this by the way? Would painting them be risky or would the paint come off because of the coolant? Anyways, if anyone could provide me with a link or something where I could buy one (preferably not ebay because i dont want to pay 15 bucks for a used housing). Thanks.
Old Jan 25, 2013 | 11:06 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: Where to buy a thermostat housing?
If you post a pic of which part you are referring to I may be able to help, pretty sure I know what you are referring to and had to find an alternative myself, just need to see it again to be sure you need the same thing.
Old Jan 26, 2013 | 05:04 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
The thermostat housing is aluminum. Im not sure of a link for a new one but if you still need a used on I have a extra one.
Old Feb 10, 2013 | 07:51 AM
skido's Avatar
Be EXTREMELY carefull installing aluminum thermostat housings! The thermostat and gasket must be seated perfectly or the housing will break. I made my own out of steel. Lucky me, I have a 1 ton lathe and machined the pipe into a bracket with a perfect press fit then welded it.
Old Feb 10, 2013 | 08:33 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Ive never had a issue with out tstat housings. Ive taken it off many many times. New gasket with some RTV and its golden. Most of the time I just make my own gaskets anyways out of bulk stock.
He said his was really rusted out?? Did they put steel ones in older thirdgens? Or is he meaning that the rust just stuck to the ate up aluminum housing.
Old Feb 10, 2013 | 09:01 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
FOUR SEASONS Part # 85223, $11.95 at Rock Auto.
Be sure to run some anti-freeze as that provides corrosion protection. Otherwise run some RMI-25
RBob.
Old Mar 7, 2013 | 11:39 PM
Cadaver_Puncher's Avatar
Car: 92 Camaro rs ( mostly stock for now
Engine: 3.1 v6
Transmission: 700r4 with a b&m megashifter.
Axle/Gears: whatever came stock. wanna posi tho
Classic industries, pick-a-part, rockauto.com, and Napa should all have them.
Old Mar 16, 2013 | 09:35 PM
xMrBadDogx's Avatar
Engine: 2.8 MPFI V6
Thanks everyone, i picked it up from O' Reilly's. I finally took care of that leak. Thanks for all your help.
Bubbajones_ya
Jul 6, 2024 08:32 PM
BumpaD82
Feb 26, 2016 02:57 PM
dbrochard
Oct 3, 2015 12:43 PM
85Special
Sep 3, 2015 04:21 PM
Formula_88AE
Sep 3, 2015 01:47 PM
