something wierd
Old Mar 19, 2013 | 02:47 AM
88rsbenjy's Avatar
Car: 88 camaro rs
Engine: stock 2.8L V6
Transmission: stock
Axle/Gears: stock
something wierd
ok so i stopped to get chinese food the other night and shut the car off. car ran fine all the way there and such. got food, went out to car turned key to start car and it sounded like battery died. ya ' know engine crank 2- 4 times, getting slower with every turn. so im like great i got a dead battery. turned key all the way off then back to try to start it again, it started and heard a knock in the engine, turned engine off then started back up and everything fine.
what in the hell is wrong with my girl? i just bought her a new muffler. WHAT ELSE DOES SHE WANT!!!!
Old Mar 19, 2013 | 04:41 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Re: something wierd
clean battery terminals?
Old Mar 19, 2013 | 04:55 AM
88rsbenjy's Avatar
Car: 88 camaro rs
Transmission: stock
Axle/Gears: stock
Re: something wierd
do i just clean them with a hard wired brush or should i use some kind of solution?
its happened before and i've noticed that it only happens in cold weather. does cold weather play into a factor with the battery. i ve heard that the cold can drain batteries but then i've heard that sticking like a AA or AAA battery it the freezer replenishes it
Old Mar 19, 2013 | 05:49 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: something wierd
I'm assuming yours is still a side post, not a top post. Take a look at the cables, the ends that screw into the battery and the battery terminals themselves. If you see any green or crusty build up, first use a hard wire brush to get the most off and then you can use a mix of baking soda and water to eat away the rest (just make sure its disconnected and dry before reconnecting!!). In severe cases you may need new cables or ends, or even a battery. But thats severe.
Edit: if you have the battery disconnected, you may wanna get it load tested to make sure its still strong enough to start in cold weather.
Old Mar 19, 2013 | 08:37 PM
JC1992rsconvert's Avatar
Car: 1992 camaro rs convertible
Engine: 3.1 liter v6
Transmission: automatic
Axle/Gears: 3.23 posi trac
Re: something wierd
ok so if you have green stuff on the terminals theres a very easy solution to clean the battery cables my granddad taught me. COKE not any after market brand but the good ole coca cola from Atlanta. seriously ive done it myself it works. hope it helps
Old Mar 19, 2013 | 08:52 PM
I'M THE BATMAN's Avatar
Car: '92 RS heritage convertible
Transmission: auto
Re: something wierd
The knock in the engine does not sound battery related. IMO
Old Mar 20, 2013 | 05:17 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: something wierd
Knock does not sound good. Next time if it happends pay attention to the lights and how far they dim or the Vt guage.
mud runner
Nov 2, 2015 07:30 PM
lanceflame44
Sep 25, 2015 12:28 PM
andy74
Sep 3, 2015 08:41 AM
Apeiron
Carburetors
Oct 18, 2001 04:54 AM
gruveb
Sep 29, 2001 03:06 PM
