does this exist?
Old Apr 18, 2013 | 01:59 PM
Cadaver_Puncher's Avatar
Car: 92 Camaro rs ( mostly stock for now
Engine: 3.1 v6
Transmission: 700r4 with a b&m megashifter.
Axle/Gears: whatever came stock. wanna posi tho
does this exist?
Just wondering if anyone made an electronic water pump for a 3.1?
Would it be worth it or is the parasitic drag of the water pump next to nothing?
Just a thought I had. Having only alternator and power steering running off of a belt might be cool.
Old Apr 18, 2013 | 02:01 PM
Blue1990camaro's Avatar
Re: does this exist?
i wouldnt bother unless your doing something lik somone on here did with a teal camaro 3.4 thats boosted to ****
Old Apr 18, 2013 | 02:02 PM
all in all it barely drags, if u wana reduce drag do like i did remove your ac and smog if your not worried about emissions,
Old Apr 18, 2013 | 03:35 PM
project89's Avatar
there are remote mount electric water pumps, that u can use but they are very expsensive.
its been a while since i looked into it but if memory serves me corectly a few years ago they ranged from 275$-500$
for a street car u dont need one , for something like my own car which sees 8,000 rpm there is an advantage, even on my car i didnt get one and have been running a modified stock water pump
Old Apr 18, 2013 | 03:40 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
If you plan to drag race it and need the extra cooling in round robbin.. or for what dave said. Else then that for the cost to have one I dont see a point.
Old Apr 18, 2013 | 09:33 PM
caffeine's Avatar
Car: 89 Firebird Formula
Engine: 3500T
Axle/Gears: 9 bolt/4.11
Just in case nobody knew this a FWD 3500 water pump pulley will bolt onto a RWD pump and will underdrive it a bit. A 3100 or 3400 WP pulley is probably the same as a 3500 pulley too.
I decided to try it out and I haven't had any cooling issues; I have the fan set to come on around 205*F but the temp mostly stays below 200* except in traffic. I also have an underdrive crank pulley.
Old Apr 19, 2013 | 06:23 AM
Engine: 3.1 v6
OK cool . Thanks. I was just wondering. Being my dd I can't justify $500 maybe for something that wouldn't show much .
My air ( smog ) pump is gone. Barely use ac but because of an injury to my neck my internal temp regulator in my body is messed up. So in 90+° weather my body temp hits 102° so access is a must.
Old Apr 19, 2013 | 10:58 AM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Removing your AC does next to nothing anyways. By taking it off your basically just reducing the value of the car.
Will the dropped weight and less drag give you a 0.001 improvement in 1/4 mile times? yes, but does it matter?
Old Apr 19, 2013 | 11:32 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
You could always do something like this...
http://www.stefs.com/bandb/products/...mpdrivekit.htm
saw that on a SBC the other day, can't speak for reliability but it seemed to work ok.
Old Apr 19, 2013 | 12:49 PM
87 Camaro Dude's Avatar
Car: 1987 Camaro SC
Engine: 2.8L V6
My uncle has had one of those (or something very similar) on his 67 Camaro for years, never had a problem. It's driven to the track and raced every weekend on Sat and Sun so the car sees plenty of action. The key is to not use a lot of belt tension or it will burn up the electric motor.
Old Apr 19, 2013 | 02:37 PM
fasteddi's Avatar
Car: 1991 Camaro RS
A few of my racing friends have those set ups. They work pretty good.
gixxer92
Apr 12, 2022 12:09 AM
InfernalVortex
Apr 20, 2021 11:31 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
1992Z28!
Nov 19, 2015 07:33 AM
t/aws61985
Sep 29, 2015 02:10 PM
