3.4 Question
Old Apr 22, 2013 | 10:05 AM
bigjake's Avatar
3.4 Question
Everything I see on the torque specifications for the rods, mains, and head bolts on the 93-95 Camaro/Firebird engine is 37 ft pounds or so. Is this correct because it seems low to me.
Old Apr 22, 2013 | 10:13 AM
xwarp's Avatar
Car: '85 S15
Engine: '93 3.4 60v6
Re: 3.4 Question
That sounds like a torque to yield spec. It's probably 37 ft-lbs plus 90 degrees if they are torque to yield bolts.
Grabbed my 3.4 service manual, which shows:
Connecting rod nut: 37 ft-lbs
Main bearing caps: 37 ft-lbs plus 77 degrees
Cylinder head bolts: 41 ft-lbs plus 90 degrees
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
92projectcamaro
Aug 6, 2015 01:20 PM
