1986 Firebird engine loping at idle and low-mid rpms
Old Apr 26, 2013 | 12:22 PM
Jdvorsky's Avatar
My 1986 2.8l firebird is loping at idle and during acceleration, and when cruising at highway speeds. It feels kind of like its surging/loping and idle rpms bounce around by +/-200 rpms.
I just changed the drivers side manifold gasket, and had to remove the plug wires on that side, is it possible one of the drivers side plugs/wires is garbage?
What should I check first?
Thanks,
Jdvorsky
Old Apr 26, 2013 | 12:39 PM
85MTBEE's Avatar
Re: 1986 Firebird engine loping at idle and low-mid rpms
My car was doing the same thing. So, I changed the rotor,cap, wires, plugs, and cleaned the Idle Air Control Valve. I used Seafoam in the Intake Manifold. DIDN'T FIX IT...
Now I am changing the injectors, fuel filter, and cleaning the intake.
I hope your isn't as bad as mine...
Old Apr 26, 2013 | 07:38 PM
ex-x-fire's Avatar
I'd look at the tune up parts & replace them if in question. Firing order is 123456. #1 is at the front pass side, #2 is at the front drivers side.
Old Apr 26, 2013 | 08:15 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
When you did the gasket set, did it seal properly through there? If you didn't get it right, the engine will know....
Old Apr 26, 2013 | 11:50 PM
Jdvorsky's Avatar
Looked at the spark plug wires today after work and they were all garbage, 1 was sliced open and 2 broke taking them off.
So I changed those out and that fixed most of the problem, still idles a tiny bit rough but I think it was doing that before the huge idle+ driving problem happened.
Old Apr 27, 2013 | 12:05 AM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Originally Posted by Jdvorsky
Looked at the spark plugs today after work and they were all garbage, 1 was sliced open and 2 broke taking them off.
Cam lope bruh
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
