Brake pcm problem?
Old May 13, 2013 | 02:39 PM
mcrandrz's Avatar
Car: 1991 camaro rs
Engine: 3.1 - looking to upgrade to 3400 hy
Axle/Gears: Stock? Lol
Brake pcm problem?
So 1991 camaro rs 3.1 today me and my teacher were checking the real times on my car with an aldl connector and computer. Something pretty odd happened when I said lets check the brake booster for vacuum leaks. (hit brake while running) the aldl cut out said no connection. We retested 5 times. I hit the brakes and my pcm (?) Cuts out. Top of that my brake lights only work when the nighttime lights are off. (head lights and such) so idk where to even start on this one ><
Posted from Thirdgen.org App for Android
Old May 13, 2013 | 03:16 PM
project89's Avatar
Re: Brake pcm problem?
get under the dash and look to se if the pedals are rubbbing on any wires
second thing to do would be to disconect the brake light switch on the pedal and see if that makes a difference
Old May 13, 2013 | 08:34 PM
mcrandrz's Avatar
Car: 1991 camaro rs
The pedals are not touching anything. Tomorrow ill try pulling it.
Old May 13, 2013 | 10:42 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
i've seen something odd like this before... ALDL communications would quit from shifting out of park.
take a good look at grounds.
Old May 15, 2013 | 10:09 PM
mcrandrz's Avatar
Car: 1991 camaro rs
So I tested a little bit. Ground for the lights / brake switch are fine. Odd though I have 12.7 volts going into the switch and 11.5 coming out.
Old May 15, 2013 | 10:11 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Did you test the voltage going in when you pressed the brakes? You'll likely find that it will be very near the same 11.5V. If it's not, then replace the switch.
Old May 15, 2013 | 11:01 PM
mcrandrz's Avatar
Car: 1991 camaro rs
Volts stayed at 12.7 but a high resistance switch won't cause my pcm to mess up would it?
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
NBrehm
Aug 25, 2015 11:49 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
