2.8 like more timing?
Old May 16, 2013 | 10:45 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Now that I found the how-to and the stock spec, I'm wondering if these 2.8s seem to like a different setting for initial spark advance? I read the FAQ sticky and the first half dozen posts of the more-power sticky, neither of them had the answer.
Old May 17, 2013 | 12:14 AM
project89's Avatar
Re: 2.8 like more timing?
set base to 14* instead of 10* , its will make a lil bit of difference.
just keep an ear out for pinging when u do it , when i first turboed my stock 2.8 i ran the stock timing curve with an addition 6* of advance and it never pinged even under boost on 91
Old May 17, 2013 | 06:59 AM
cosmick's Avatar
Thanks!
I'll report back on my findings.
Old May 22, 2013 | 05:14 PM
cosmick's Avatar
I'm not sure it ended up anywhere near 14*, but it is moved. I have hard starting, but when I floor it from a stop it spins the right rear! This is an improvement to driveability, so next will be checking what it does to gas mileage.
Old May 22, 2013 | 06:14 PM
project89's Avatar
sounds like ur way past 14* as 14* base shouldnt cause hot start issues
Old May 22, 2013 | 07:17 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
I ran 15* before I was tuning and didnt really have problems with a hard start....
Old May 22, 2013 | 07:26 PM
cosmick's Avatar
After driving home I think I'll back it off slightly. Only this time not loosen the hold down clamp so loose.
Old May 23, 2013 | 04:35 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Yea that dizzy clamp down is a pita. This is one thing I like about ford..the dizzy is in front so it can be a easier to adjust.
Old May 23, 2013 | 12:43 PM
cosmick's Avatar
Finally, success!
My import timing light isn't good, but I'm sure I'm above 12*, and I have instant fire-up.
I guess my rough idle and hesitation is something else. Going to try cleaning the idle air control thing next, may have carbon deposits or some such.
Old May 23, 2013 | 04:01 PM
Cadaver_Puncher's Avatar
Car: 92 Camaro rs ( mostly stock for now
Engine: 3.1 v6
Transmission: 700r4 with a b&m megashifter.
Axle/Gears: whatever came stock. wanna posi tho
Rough idle? Have you checked for vacuum leaks?
Old May 23, 2013 | 04:31 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Have you done a idle relearn?
Old May 24, 2013 | 08:19 PM
cosmick's Avatar
I looked, next is misting some starting fluid at it, hoping to hear it gain revs for a second. That's what a carb would do, not sure if EFI will or not.
Old May 24, 2013 | 08:20 PM
cosmick's Avatar
I'll do a search in a few minutes for what it is and how to do it. Thank you for bringing it to my attention.
Old May 24, 2013 | 08:39 PM
cosmick's Avatar
Wow! So many relevant results! Froddoyo's thread looked close, read it, it looks helpful. I'll try that tomorrow.
Cleotiz
Jan 6, 2018 08:56 PM
E Rod
Aug 28, 2015 05:17 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
86Base
Aug 8, 2015 01:34 PM
