WinALDL on an '87 2.8L V6 - Runs good in Open Loop, bad in Closed Loop
Old Sep 13, 2013 | 02:59 PM
  #101
OdieTurbo's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 3.4L V6
Transmission: T5 (NWC)
Axle/Gears: 3.42 Stock axle
Re: WinALDL on an '87 2.8L V6 - Runs good in Open Loop, bad in Closed Loop
I got the info from this post: https://www.thirdgen.org/forums/v6/1...ctor-size.html
Injector Info:
2.8 13pph*
3.1 15pph
3.4 17pph
Now I have come across other sites showing 15pph for the 2.8 as well. And some saying 19pph for the 3.4.
Here's the part numbers from RockAuto:
2.8L - ACDELCO Part # 217-286 or ACDELCO Part # 217-284
3.1L - ACDELCO Part # 217-267
3.4L - ACDELCO Part # 217-301
That seems to me that there are three different ratings... I'll try to find the ratings for those on the web.
Old Sep 13, 2013 | 07:37 PM
  #102
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
2.8 stock injectors are either 15.4 or 14.7 lb... So are the 3.1s. 3.4s are 18.4.
Old Sep 18, 2013 | 08:33 PM
  #103
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Any progress ?
Old Sep 19, 2013 | 09:19 AM
  #104
OdieTurbo's Avatar
Engine: 3.4L V6
Any progress ?
Not yet, this week has been crazy with vet visits, and doctors appointments. I've had to work late every night! I've even got to work until 6 tonight (usually 5), but I should have time to swap the thermostat and chip tonight!
Old Sep 19, 2013 | 09:24 AM
  #105
Engine: Lb9
Transmission: M20
I hope you don't have fleas lmao
Old Sep 19, 2013 | 09:00 PM
  #106
OdieTurbo's Avatar
Engine: 3.4L V6
I swapped out the thermostat, the 160 is back in!
Then I put the 23.5% chip in and took it out for a spin! The BLM was better, but still down in the 100-115 range most of the time. Still too rich.
So, I put the Tuned Performance "Special" chip in and took it out for a spin. The BLM stayed around 128 the whole time! We did it!
I've attached the log files so they can be looked at. But for now, I think we're successful!
File Type: zip
Old Sep 20, 2013 | 06:49 AM
  #107
OdieTurbo's Avatar
Engine: 3.4L V6
Additional note this morning:
When I got to work, I could smell something hot so I popped the hood. Though the coolant temp is only ~160 degrees, the exhaust manifolds were VERY hot. Looks like I may have a lean condition under acceleration (I've got a steep hill about 1/2 mile long up to my work).
I'll do some more logging and testing tonight. If it is too lean, I'll just switch back to the chip with 23.% less fuel and no "special" modifications.
Old Sep 20, 2013 | 01:06 PM
  #108
project89's Avatar
a wideband 02 sensor would be a great investment, if not that then atleast hook a volt meter to the stock narrow band 02 or buy one of the cheap 20$ narrow band afr gauges , while nowere near as accurate as a wideband it will atleast give u a good idea of whats going on with a glance at the gauge while driving
Old Sep 20, 2013 | 01:21 PM
  #109
OdieTurbo's Avatar
Engine: 3.4L V6
Ouch, the wideband sensors are pretty pricey I'll have to save a bit for that.
Old Sep 20, 2013 | 01:56 PM
  #110
project89's Avatar
aem ugo can is what i run in my turbo car , u can get one for around 165$'s new
Old Sep 20, 2013 | 05:30 PM
  #111
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
I got the slc-diy2 kit. Love it. It was about 180 bucks with the sensor. does alot of pretty cool things.
Old Sep 21, 2013 | 10:15 AM
  #112
OdieTurbo's Avatar
Engine: 3.4L V6
Thanks for that tip! That's a pretty decent price, much more affordable
Old Oct 1, 2013 | 09:42 AM
  #113
OdieTurbo's Avatar
Engine: 3.4L V6
Okay, the Hypertech with a 23.5% fuel reduction gave me about 19MPG. I've not got the Hypertech with additional custom mods by Tuned Performance. Hopefully this gets us up in the mid to low 20's.
Old Oct 1, 2013 | 10:03 AM
  #114
Engine: Lb9
Transmission: M20
That's a awesome improvement
Old Oct 9, 2013 | 03:45 PM
  #115
camaro_V6_Tuner's Avatar
Car: 2002 Trans Am WS6
Axle/Gears: 4.10
How much are you driving it? Is it running like it should now? Get the 'hot exhaust manifold' figured out?
Old Oct 9, 2013 | 03:48 PM
  #116
OdieTurbo's Avatar
Engine: 3.4L V6
Doh! I forgot to update! I'm getting about 19 MPG now. Driving it daily during nice weather, I've put over 1,000 miles on it already The hot exhaust manifold just appears to have been it burning off built up carbon. It's no longer a problem.
It's still a bit rich but a lot better! I hope to get a burner and try some more changes to the EPROM. I'm going to put my data analyst skills to good use and try to come up with changes to the pulse width and MAF tables based on the engine size increase.
Old Nov 3, 2013 | 07:07 AM
  #117
OdieTurbo's Avatar
Engine: 3.4L V6
Tuned Performance just sent me another chip with more aggressive fuel reduction. I'm going to try to get another log today.
Old Nov 3, 2013 | 12:35 PM
  #118
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
dunno your target but im at 23-25MPG 50/50 mix of city highway. many money ago when premuim was only $1.65gal I could get 28 on ultra 94
Old Nov 3, 2013 | 01:10 PM
  #119
OdieTurbo's Avatar
Engine: 3.4L V6
Yeah, I'm hoping for about 24 MPG
Unfortunately, the chip I just got was no good Don't know what happened yet - but I'm not upset with Tuned Performance! He's been great so far!
Old Nov 3, 2013 | 07:42 PM
  #120
fasteddi's Avatar
Car: 1991 Camaro RS
I think the going rate for a good solid V6 thirdgen is 20-25 when its mixed driving. Back when I drove 3 hrs a day of highway driving when my car was the dd it was getting upwards of 25-30.
Old Nov 4, 2013 | 11:07 AM
  #121
project89's Avatar
it also depends on the area ur in , if ur in a hilly area ur not going to get as good as somone who lives were its flat
same goes for altitude
Old Nov 4, 2013 | 11:41 AM
  #122
OdieTurbo's Avatar
Engine: 3.4L V6
My '85 with the V6 and TH700-R4 got about 24 tooling around town, so I figure this one should get about the same.
Old Nov 4, 2013 | 11:51 AM
  #123
project89's Avatar
u shoudl be able to , my twin turbo iroc is pulling down 25+ in town i love it , i put 20-30 bucks in it every 2 weeks. my truck on the other hand gets measly 7-8 mph in town, im hoping we dont have a bad winter this year so i can drive the iroc around , i go broke driving the truck
Old Nov 4, 2013 | 05:24 PM
  #124
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
IM sure I could get more, exhaust fumes will choke ya like a 70s BB
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
BurlyChev
Aug 16, 2015 09:08 PM
gwade12
Aug 8, 2015 08:17 AM
mvftw
Oct 22, 2001 04:13 PM
