Combating carbon Fiber build, QUICK!!!
Old Dec 26, 2013 | 05:41 PM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
It looks like a buddy of mine has a carbon fiber build up starting early, is there a way to combat this before it get anymore worse?...It just started a week ago after driving around all the day, by 6pm the car was started and it acts like it wants to stall out now, and only does it when running, but has now it also chugs while idling too!...I was told to get some Seafoam, so what kind do I get and how long does this stuff need to run for to get the engine cleared???
Any kind of help will be greatly appreciated!!!
Old Dec 26, 2013 | 07:08 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Combating carbon Fiber build, QUICK!!!
i think you meant, carbon build up,...not carbon fiber?
seafoam comes with directions. a lot of people like seafoam.
you can also use water to do the same thing. keep the engine running while you slowly pour a cup in the throttle body, then go down the highway and beat on it. you'll hear carbon deposits exiting threw the exhaust.
Old Dec 26, 2013 | 09:37 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
1. Knowing what year car would help. Some cars you can't just plug in the ECM and go...
2. The 60*V6 is notorious for running slightly on the rich side, especially during acceleration, where it is tuned that way even stock (generally likes 12.5:1 or so, as I've read).
Old Dec 27, 2013 | 12:46 AM
92g92's Avatar
Car: 1992 Camaro Z28
It has a carbon fiber build up problem....wow
Old Dec 27, 2013 | 08:03 PM
sheltonw3's Avatar
Engine: Classified
Well, either way, I'm dropping in some seafoam and just let it rip!
Old Dec 27, 2013 | 09:32 PM
Engine: 2.7L V6
Axle/Gears: 4.41
SeaFoam isn't going to help if the problem is a clogged IAC or other idle air passage or possibly EGR or something. And I have personally seen SeaFoam foul out plugs (happened to me).
Old Jan 12, 2014 | 01:16 PM
Cadaver_Puncher's Avatar
Car: 92 Camaro rs ( mostly stock for now
Engine: 3.1 v6
Transmission: 700r4 with a b&m megashifter.
Axle/Gears: whatever came stock. wanna posi tho
Seafoam is also known to damage ( or so I've heard) o2 sensors.
Twin_Turbo
Mar 14, 2016 10:10 PM
Jorlain
Oct 8, 2015 01:57 AM
R13_Braz
Sep 18, 2015 05:00 PM
corey8084
Sep 17, 2015 02:56 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
