code 15 coolant temp sensor location?
Old Jan 15, 2014 | 07:51 PM
mikey8494's Avatar
Car: 1986 camaro iroc z
Axle/Gears: stock
im throwing code 15 and i needto find were the coolant temp sensor is so i can replace it so my fan will stop running constantly. so were is it? thanks
Old Jan 15, 2014 | 08:13 PM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Re: code 15 coolant temp sensor location?
Coolant temp sensor is underneath the throttlebody, yellow wire and black wire leading to it.
But it sounds like it may be the rad fan switch, back of the passenger side head.
I believe these are only locations on the 2.8/3.1, but wait for confirmation for someone else first.
The coolant temp sensor under the TB is the input for the ECM, the sensor on the pass head is for the rad fan switch, there is another coolant sensor on the front of the drivers side head, this goes to the gauge cluster.
Old Jan 15, 2014 | 08:20 PM
mikey8494's Avatar
Axle/Gears: stock
but its throwing code 15 coolant temp sensor thing
Old Jan 15, 2014 | 10:12 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The ECM's CTS is at the front of the intake nearly under the TB. It has two wires going to it.
There isn't a fan coolant switch in the passenger head. So don't worry about that, which isn't there.
RBob.
Old Jan 15, 2014 | 11:17 PM
willexoIX's Avatar
RBob.
Thanks for the correction, but what sensor is in the back of my passenger head? unless its only on the 2.8?
Old Jan 16, 2014 | 07:56 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Fan switch, on the 2.8's the ECM or the switch can turn on the fan. On the 3.1's the fan is only under ECM control.
Of course there is more to it (on 3.1's), such as having either the engine temperature or the A/C pressure status switch to the ECM telling the ECM to turn on the fan.
RBob.
Bstrang6
Sep 8, 2015 04:29 PM
Bert87
Aug 23, 2015 03:50 PM
Rustyweb7
Aug 9, 2015 03:05 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
