looking to do some head work.
Old Jan 29, 2014 | 02:09 PM
mikey8494's Avatar
Car: 1986 camaro iroc z
Axle/Gears: stock
ive been wanting to do a good cam on my car to give it lope and i decided it be best to get better flowing heads and intake to get the best and wa wondering what options do i have do 3500 aluminum heads mount up to my 3.1 and if so the i can add a 3100 supercharger to i think either way just focusing on heads at this point what options do i have to get the best flow.
Old Jan 29, 2014 | 02:35 PM
34blazer's Avatar
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
Re: looking to do some head work.
3100 never had a supercharger.
Old Jan 29, 2014 | 03:17 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
3500 heads wont go onto a 3.1L or a 2.8L.
3500 only will fit up to a 3400 or obvously a 3500.
You can use 3100/3400 heads on the 3.1L but make sure you get the large port ones. I cant remember the years off hand as im new to the whole hybrid thing but I know my 2002 3400 impala heads are large ports.
Old Jan 29, 2014 | 04:38 PM
mikey8494's Avatar
Axle/Gears: stock
can you mount a supercharger to those heads?
Old Jan 29, 2014 | 06:07 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
No direct fit.
Old Jan 29, 2014 | 07:53 PM
mikey8494's Avatar
Axle/Gears: stock
ok then ill do a 4.3 swap to be different
Old Jan 30, 2014 | 06:12 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
If you are going to do all the work of swapping a 4.3, you can put in a 350 for the same amount of effort and a better outsome. a 4.3 is literally a 350 with 2 cylinders missing. The mounting is the same, the trans needed is the same.....
Old Jan 31, 2014 | 08:32 PM
mikey8494's Avatar
Axle/Gears: stock
yea and id be jumping on the " just swap a v8" wagon i wana be different not a follower but either way a 350 may be better
Old Feb 1, 2014 | 03:28 PM
fasteddi's Avatar
Car: 1991 Camaro RS
If u want to swap to a v8 then do it. If not then stick with the v6 and make some hp. You have a great engine that can take some abuse and a good ECM toe sizably tune. It's possible. There was a solid 14.90s all motor 3.1l v6 on here and my high 12 sec turbo 3.1 so it is possible. Just saying.....
Old Feb 2, 2014 | 05:23 PM
mikey8494's Avatar
Axle/Gears: stock
what
Jake_92RS
Jan 28, 2020 10:37 PM
beastin91rs
Oct 9, 2015 07:38 AM
Reddeath210
Oct 6, 2015 08:20 AM
g.l.mos
Aug 22, 2015 12:02 AM
