no fire help asap
Old Jun 25, 2014 | 10:07 PM
rsk subzero's Avatar
Car: 88 camaro rs
Engine: 2.8 v6
Axle/Gears: stock
no fire help asap
Ok I have the 2.8 and I have power at the coil changed the rotor cap i gn module still no fire to the plugs
Old Jun 26, 2014 | 07:38 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: no fire help asap
Are you saying you have 12V at the coil? Have you tested for 12V both into and out of the coil? How are you testing for spark? Shooting in the dark, I'd say you need a new coil.
Old Jun 26, 2014 | 07:45 AM
Car: 88 camaro rs
Engine: 2.8 v6
Axle/Gears: stock
My coil putting out power it's frm the cap to the plugs no fire
Old Jun 27, 2014 | 10:51 AM
drdave88's Avatar
Engine: 6.0L
Have you ohmed out the ignition module to make sure the one you got was good? Its rare but could be a bad part. Try a search on this board, there should be a thread or two about testing all of the ignition components, resistance values and all that. ave you tested for proper power/ground and all that going to the ICM? Any chance of getting ahold of another distributor to swap and test?
Old Jun 28, 2014 | 03:18 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Check the 2-wire connections at the coil and ignition module. Don't just look at them, flex the wires at each connector. I had an almost broken wire on one end of it right at the connector and had to hunt for a replacement.
And check for an AC voltage coming out of the pickup coil while cranking the engine and also that the PU isn't wired to the module backwards or one of the terminals has come out of the connector body and isn't making contact with the module terminal.
RS Reaper
Oct 17, 2018 07:52 PM
86White_T/A305
Mar 6, 2016 01:48 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
indygene
Sep 26, 2015 11:21 AM
92projectcamaro
Sep 24, 2015 08:09 AM
