89 rs v6 low oil pressure at idle
Old Jul 10, 2014 | 07:43 PM
Dutch420's Avatar
Car: 89 RSt-top
Engine: 2.8 mpfi
Transmission: auto
Hey guys been doin a bit more pokin in to my new to me car.. When its first started oil pressure sits at about half jumps up when ya hit the gas. But when it get warm to make the rad fan turn on oil pressure sits at about red line..
Old Jul 10, 2014 | 08:59 PM
project89's Avatar
Re: 89 rs v6 low oil pressure at idle
dont trust the stock gauge , go buy a cheap 15$ mechanical oil presure gauge and hook it up temporaily to verify oil presure
to hook it up u can unscrew the stock sending unit above the oil filter and hook the mechnical gauge in its place
Old Jul 11, 2014 | 08:39 AM
Dutch420's Avatar
Car: 89 RSt-top
Engine: 2.8 mpfi
Transmission: auto
Hi project89.
I def will check with a pressure gauge. There are no knocks or ticks in the motor so.. I cant see it being the motor. I would think different if the gauge did not jump up when ya hit the gas. It has a stumble when ya first hit the gas but seems to run fine when if ur on it.
Old Jan 5, 2015 | 07:42 PM
Dutch420's Avatar
Car: 89 RSt-top
Engine: 2.8 mpfi
Transmission: auto
so im pretty sure i may have found the problem..lol or part of it..
the sensor by the oil filter (oil pressure) i think. was barely threaded into its base. also had a small leak from there too. seems better since i tightened it.
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
