5/32" vacuum hose terminates near smog pump
Old Jul 29, 2014 | 09:03 PM
whatdayasay's Avatar
I have a 5/32" vacuum hose that comes from a tee near the intake and I think it goes to the air distributor (air management valve) behind the smog pump. The hose is shot and needs to be replaced, but I pulled the old hose near the smog pump off the connection and I can't find where it was hooked up. Would taking the alternator off help? I've got the car on some low ramps and spent a few minutes looking with no luck. Any advice?
Old Jul 29, 2014 | 09:05 PM
Re: 5/32" vacuum hose terminates near smog pump
1990 3.1L EFI
Old Jul 30, 2014 | 04:56 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
This should help, view from back of pump assembly...
RBob.
Attached Thumbnails 5/32" vacuum hose terminates near smog pump-camaro_air_1a.jpg
Old Jul 30, 2014 | 09:30 PM
RBob.
Thanks!
That helps a lot!
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
db057
Sep 4, 2015 07:57 AM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
