2,8 throttle body on a 3.1. VAC question.
Old Aug 31, 2014 | 06:59 PM
crazybird's Avatar
Car: 1987 firebird
I have a 2.8 tb on my rebuilt 3.1. i am wondering if the idle air bypass hose can be routed to any vacuum source? right now i have it routed to the port on the back of the plenum. it will idle like this, but will not idle when it is disconnected. also the ccv valve I just put a cone breather on the hole. will this be ok? The car has after market valve covers and only has two holes. one hole on each cover. thank you guys. its good to be back working on the car again.
Old Sep 4, 2014 | 05:04 AM
crazybird's Avatar
Car: 1987 firebird
Re: 2,8 throttle body on a 3.1. VAC question.
please? anybody?
Old Sep 7, 2014 | 08:04 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
The engine won't idle because your setup is wrong. You need to connect the port on the back of the intake to the port on the throttle body.
Pics would help.
Old Sep 7, 2014 | 10:13 PM
crazybird's Avatar
Car: 1987 firebird
yes sir, but the 3.1 doesnt have the port on the intake. i also have the 3.1 TB. should i use that one instead?
Old Sep 8, 2014 | 03:04 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Having a breather filter on the valve covers is fine. Wont hurt the car. Just make sure you cap any lines that could cause a vacuum leak.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
