bypassing heater control valve and retaining heat.
Old Nov 3, 2014 | 09:56 AM
mikey8494's Avatar
Car: 1986 camaro iroc z
Axle/Gears: stock
im looking for a way to by pass the hcv valve completely this is the 3rd one cracked in 4 months its gona get cold and i realy want to have heat in my bird since its my daily driver
Old Nov 5, 2014 | 01:43 AM
thatoneguy5x's Avatar
Car: camaro
Engine: 3.1
Transmission: auto
Re: bypassing heater control valve and retaining heat.
you can just connect both lines with a pipe fitting. the only problem is hot coolant is gonna be running through your heater core all the time. ive seen a couple threads on this on the site.
Old Nov 5, 2014 | 06:01 PM
mikey8494's Avatar
Axle/Gears: stock
is there a down side to that seeing the acy doent work any way when it nice out i just open up the windows and drop the t tops
Old Nov 5, 2014 | 06:11 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
just go to hardware store and put a brass gas/water valve on the line into the core, [ screw in brass hose barb ends ] only down side is you gotta pop the hood when you want heat or not.
My wagon is like that.
Old Nov 6, 2014 | 12:19 AM
mikey8494's Avatar
Axle/Gears: stock
s i plug the hose coming out into one of the hoses then the other hose i run to the radiator ?
Old Nov 6, 2014 | 07:55 AM
project89's Avatar
u cannpot just close off the line , that line also bypasses water around the thermostat to circulate the water.
take a picture were the heater valve hook sup and ill tell ya what lines to connect together to do it the right way, then in the sumer u can flip the 2 lines so u dont have hot water circulating threw the heater core when u try to use the ac
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
