91 3.1 Antifreeze issues. Help!
Old Dec 6, 2014 | 02:24 PM
bgilman993@live's Avatar
Car: 91 Camaro
Engine: 3.1 V6
Hey guys,
Its not really a overheating issue. Several times my antifreeze has boiled. Never really over heats while. Ive been noticing ive been leaking a bit of antifreeze on the front of the motor and puddles on my k member. My first thought was the weep hole on the water pump. But this really doesnt seem right. My hoses are fine. Has new intake gaskets plenum gaskets. It leaks until the overflow is empty and then nothing. The radiator always stays full. Hasnt went down at all. Any ideas would be greatly appreciated!
Old Dec 7, 2014 | 06:30 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: 91 3.1 Antifreeze issues. Help!
Check the freeze plugs too.
Old Dec 7, 2014 | 01:49 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Check where the pipe for the throttle body and heater core goes into the adaptor for the intake. I've had issues there before. It pools in the depression on the block and then runs down the side of the timing cover to drip down by the oil pan. You squeeze the clip to remove the TB pipe and check for bad o-rings on the pipe.
And check your oil and look at your exhaust sometime... Could be worse than you think (head gasket).
Old Dec 7, 2014 | 06:44 PM
Car: 91 Camaro
Engine: 3.1 V6
Any way you could show me where and explain more?
Old Dec 7, 2014 | 06:46 PM
Car: 91 Camaro
Engine: 3.1 V6
I also thought the head gasket, explains the boiling. But i tried the brake cleaner with it running and i sprayed everything and nada
Old Dec 7, 2014 | 07:00 PM
Car: 91 Camaro
Engine: 3.1 V6
Aso thought of freeze plugs but all the leakage is in the front. not the sides.
Old Dec 7, 2014 | 08:04 PM
Engine: 2.7L V6
Axle/Gears: 4.41
1. Follow the rubber hoses out of the bottom of the throttle body to the pipe you need to examine. I don't have a pic and I no longer have a factory top end so I can't help much on this any more. All I can say is that if the factory parts are bad, you CAN get a replacement intake manifold fitting but you will need to fight with it to get it to work. You will need a couple extra o-rings on the pipe to get it to seal right if it's leaking.
2. Spraying brake cleaner on the outside of the engine isn't going to do anything if the head gaskets are leaking coolant into the engine. If one of the coolant jacket passages is exposed and open to the cylinders, the coolant will be boiled in the combustion process and come out as sweet smelling steam in the exhaust. Check your oil just in case.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
Elephantismo
Feb 13, 2019 12:51 AM
cking99
Sep 22, 2015 11:33 AM
bryan623
Sep 19, 2015 10:13 AM
