Fuel pump making high pitched sound
Old Dec 31, 2014 | 12:35 PM
Kxracer's Avatar
I have an 87' 2.8 v6 I've had this car for over a month. It's not in too bad of shape for the year model trying to work out some of its problems...
I noticed the fuel pump can make a kind of loud sound you could say it sounds like Darth Vader's fighter plane. It still seems to be working OK but I've read that could be a sign that it's going out! So I'm going to work with replacing it in time before it does. From what I've read i'm going to make a trap door instead of dropping the rear end. Use shears to cut out the panel my main concern is cutting the fuel lines to get the pump out. I know you definitely don't want any sparks or Kaboom! Looking for advice from people who have done it. I've read people using a hacksaw to cut the fuel lines maybe going real slow as you make the cuts
Old Dec 31, 2014 | 12:52 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Fuel pump making high pitched sound
I just used tin snips, then reshape the end with pliers. Make sure you hard wire in the new FP, DO NOT use the plastic quick connect they provide. As the new pump doesn't plug in, you have to splice it in. Twist connect the wires.
Gas is what cools the FP, so if someone ran it low all the time it can go quicker.
I just used SS covered FI hose to splice lines back, wit hdouble hose clamps on the ends. If you need to make a sharp bend and the hose wants to kink, put hose clamps in the bend to make it stay round and flow well.
Id did the door also, glad so, I was back in there a few times. Much easier to do with a hole.
Old Dec 31, 2014 | 12:57 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
On you mark....
Get set....
Old Dec 31, 2014 | 01:03 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Not pics of mine but show where stuff is.
Old Dec 31, 2014 | 01:19 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Don't cut a hole in the car. Its really not that difficult to remove the tank, just takes time.
Old Dec 31, 2014 | 01:20 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
GO!
Old Dec 31, 2014 | 01:40 PM
Kxracer's Avatar
What did you use to cut the steel lines with? What do you think is a reliable fuel pump? I think the trap door is the way to go just do a nice neat job if you can
Old Dec 31, 2014 | 02:18 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I used tin snips to cut the hard line, then used pliers to reshape back open. I got my pump from autozone.
Old Dec 31, 2014 | 06:32 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
NO STOP..Your pump is not going out . Stock pumps last 200xxx .at least mines .still going strong. Check you vacuum lines from the charcoal canister to the throttle body. Thats were your problem is. Easy fix . Inspect the valve and canister.
Old Dec 31, 2014 | 06:51 PM
Kxracer's Avatar
There is a valve on the back of the intake the hose was deteriated and the line ran to the canister it wasn't plugged into anything. I couldn't figure out where it plugged into I replaced the hose and then plugged the line until I figure out what to do with it...
Old Dec 31, 2014 | 07:27 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Im not sure on the 2.8 but on my 3.1 the hose from the canister goes to one of the holes on top of the throttle body. The othe hole on the tb conects to the fpr and smog pump via a t fitting. The holes on the back of my intake .one is for the map sensor. And the smaller one goes to the vaccum ball by the battery.
Old Jan 1, 2015 | 01:33 AM
project89's Avatar
if ur going to cut an access dorr do it the right way, not like that mess in the pictures posted , also do not use tin snips or a hacksaw on the lines , goto the hardware store and buy a 5$ tubing cutter
Old Jan 1, 2015 | 09:34 AM
Kxracer's Avatar
I plan on buying a tube cutter flaring kit...the way the steel lines are bunched together I don't know if you can get a tube cutter on them. I bought a OEM service manual i'll see if I can use it to trace the vacuum lines and make sure that's not the problem. I will still work with making a access panel so it will be ready if I ever need to replace the fuel pump
Old Jan 1, 2015 | 10:32 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
no room for a tubing cutter, even a mini one, trust me I tried, on the metal to avoid cutting anything needed I used an air chisel. noisy, gotta straighten the endges some but it makes for a tight fit when its going back as no material was removed.
Old Jan 1, 2015 | 02:02 PM
project89's Avatar
mini tubing cutter fits just fine i have an access door in mine, the other few thousand ppl on this site that have access doors says the mini tubing cutter works as well
Old Jan 18, 2015 | 04:26 PM
Stewie's Avatar
Car: 1992 Firebird
Engine: 3.1L
Transmission: Manual T5
Axle/Gears: Stock
Originally Posted by Bob88GTA
GO!
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
beachrodder
Aug 25, 2015 08:05 AM
Kaweh
Aug 9, 2015 02:54 PM
