oil pan bolt sizing urgent!!
Can anyone seem to find any oil pan bolts I have an 87 firebird manual with the v6 engine. I've looked everywhere online and in my Haynes manual and cant find a replacement bolt setm would anyone know what size bolts I would need i ruined a few changing the oil pan gasket and I've tried regular bolts with the sizing for a small block gm and they didn't fit. This is my last effort to find out where I can get some or what size they are. If this info is needed it had a mixture of studs and bolts before. 2 larger bolts for the rear and 10 more smaller bolts. Please let me know any info would be much appreciated I just need to get the oil pan back on.
Transmission: 5-speed/T-5
Re: oil pan bolt sizing urgent!!
The smaller bolts will be m6, but don't recall the thread pitch, and the larger studs will be m8, again I don't recall the pitch.
For some reason I used the same size for all my bolts when taking them out I'll have to check the size. I matched the bolts with other bolts that were 5/16 x20 or 28 something like that but for some reason they don't work the threads appear to be the same but I could be wrong. I've check every home improvement store just to even find the size so I can just put regular bolts back in I don't need the studs. Checked for replacements online and it was a dead end. Its like no ones ever changed the bolts before.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
when taking out bolts I use cardboard.old pizza box, rough draw part n poke hole for the bolts in gen location and order.
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
you could always go to the local salvage yard for them, i am sure they have a ton of them
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
M6x1.0 by either 12 or 16mm and M8x1.25 by the same length... NO SAE HARDWARE ON THE 60* V6 unless it was rethreaded!
And you do need the studs for the front 2 holes unless you plan on having the harness just hanging there where it could rub up against the crank damper
. They hold the C-shaped bracket on there that the wire harness clips to to keep it from flopping.
. They hold the C-shaped bracket on there that the wire harness clips to to keep it from flopping. Thread
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
