3500 swap and prep for turbo
Old Jan 17, 2015 | 08:10 PM
The Mechanic's Avatar
Car: 89 firebird
Engine: 2.8 v6
Hi
I plan swapping a 3.5 v6 with a turbo set up later on in firebird and have couple of questions
Do I need to upgrade any engine internals (pistons,rods, valves,etc) or will a water meth injection system work?
Twin 3582r or a single 4088 turbo?
I want make about 450 500 + hp @10 + psi and be totally streetable and reliable. I would like to be able to swap the engine in, figure out the tuning process on the N/A engine, and then put the turbo set up on and not have to pull the engine back out.I plan to run a wot stage 2 turbo cam. I've done light research about using 305 forged pistons but havent seen anyone use them in a build yet or if it is even need.
Old Jan 17, 2015 | 08:45 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: 3500 swap and prep for turbo
I'm running about 10 PSIG (intercooled) on a completely stock bottom end 3500.
The only "internal" changes I have made was to aftermarket valve springs, because the stock springs are known to be very weak.
I plan to push this as far as I can on stock internals, and from what I've seen of other people's attempts the 3500 will take a LOT of abuse. The key is a good tune.
Old Jan 18, 2015 | 10:02 AM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
I plan to push this as far as I can on internals, and from what I've seen of other people's attempts the 3500 will take a LOT of abuse. The key is a good tune.
What he said. I have run 10psi in my bone stock 2.8, with a one time boost spike to 15psi, for 7 months with no problems. I have turned mine down to 6psi cause the turbo is inefficient at 10psi plus the trans doesn't like it too much. I am also intercooled.
Old Jan 18, 2015 | 11:43 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Is your 3500 a non vvt engine?
Old Jan 20, 2015 | 04:58 PM
Car: 89 firebird
Engine: 2.8 v6
It will be. I haven't gotten one yet . I'm shooting to get a 2004 or 2005 engine . I'm thinkin I should try to get a low mileage motor since I prob won't be doing any major internal work now.
Old Jan 26, 2015 | 03:55 PM
Shaun41178's Avatar
3.5 lx9 I am guessing and not 3.5 lz4
any thought of doing an lz4 or lz9 instead?
A single turbo will get you your goal no twin setup neaded
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Dialed_In
Aug 20, 2015 01:45 PM
jharrison5
Aug 19, 2015 05:53 PM
86White_T/A305
Aug 17, 2015 12:16 AM
