I have a vacuum leak(?) and I need help identifying some stuff.
Old Mar 2, 2015 | 07:53 PM
darren8642's Avatar
So I have been having trouble recently with my car. It is a 1986 Firebird MPFI. It has been having a rough idle, lack of power, and lower mpg. I checked my engine light codes and it read a 23 and 34. I replaced my IAT/MAT sensor but the code 23 still persists. Although I have unplugged my battery to try and clear the OBD memory, I haven't actually ran my car to check it again. That is a minor problem but next is the real issue.
I have a new hose to replace the old plastic one that connected to the circled thing in the picture. I don't know where it goes. My dad saw another connector that was open and connected it to that. My problem still persisted. I have been doing some research and in the Hanes repair manual it says that earlier MPFI v6 models don't have a MAP sensor. Initially I tried looking for it and came up with something that barely resembles a MAP sensor and has a white thing sticking out in the other pictures. This is where I am stumped. Is this a barometric pressure sensor? How come it has a different plug than other parts I see online? Is this where the open vacuum line plugs into?
I recently replaced my MAF sensor so I don't understand why it would be giving me the check engine light. I don't know what else it could be considering I replaced both the IAT and MAF sensor.
I'm figuring out how to put in pictures so it may not be up yet.
http://imgur.com/a/lF2ky
Old Mar 2, 2015 | 09:13 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: I have a vacuum leak(?) and I need help identifying some stuff.
Check out thread #24 on the link below.
https://www.thirdgen.org/forums/tech...iagrams-i.html
Old Mar 5, 2015 | 12:00 PM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Yup. Vacuum switch to the nipple circled in red.
86IROC112
Nov 27, 2015 09:54 AM
sreZ28
Oct 22, 2015 08:21 AM
85 Jimmy
Sep 30, 2015 07:56 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
