Lifter Problem with big cam?!?!
Old Jun 10, 2015 | 08:04 PM
Jonny45's Avatar
Car: 1988 Firebird
Engine: Built 3.4 swap
Transmission: worldclass T5
Axle/Gears: 3.23 28 spine posi with moser axles
Ok well I just finished up my 3.4 swap but I cant seem to get
the valve chatter under control....Maybe they are collapsing?
Specs on what im running
280 delta grind
1.6 rocker
.500 lift
with a 305 open pressure
I have a set of blue racer lifters in it with a
1/3-1/2 turn preload(was 1/4 to start)
and I do have a high volume melling pump in it also
Thanks for the help guys most of the time I can get the engine stuff down but this has me stumped
Old Jun 11, 2015 | 11:26 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Lifter Problem with big cam?!?!
280 delta grind
1.6 rocker
.500 lift
What is the bind hight on the valve springs your using? That .500 lift the cam specs using 1.5 rockers correct? So your 1.6 rockers pop out .533 inches of lift. I'm just curious what the specs are on those springs your using.
So what is your installed valve hight minus you spring bind hight?
Old Jun 11, 2015 | 11:45 AM
Jonny45's Avatar
Car: 1988 Firebird
no bind I have 110 thousands between the coils and the cam is 470 with 1.5 and 500 with 1.6....the seat pressure is 115 if that helps any
beastin91rs
Oct 9, 2015 07:38 AM
Mickeyruder
Sep 2, 2015 02:45 PM
cstrobel65
Aug 15, 2015 10:19 AM
Fronzizzle
Aug 9, 2015 01:15 PM
