Battery post's corrosion Problem?
Old Jun 17, 2015 | 12:39 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
I have a v6 3.1 and every once in a while, I have to change the battery posts because the corrosion doesn't let the electricity flow. A big crust of corrosion forms on both post's. I'm wondering what could be causing this problem? I had the batt and alternator checked at the autoparts store and they said it was good but im starting to think its the alternator. Any clue?
Old Jun 17, 2015 | 08:54 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Battery post's corrosion Problem?
clean posts and connections well , remove all corrosion . I like to use a small wire brush (like a USMC tooth brush) available at most dollar stores . then a light coat of di-electric grease to all surfaces . apply with a small brush , tubes of this grease available at any auto parts store . store brushes and remainder tube of grease in a zip-lock bag for future use . also good for use on bulb & sockets . should take care of your problem . good luck .
Old Jun 17, 2015 | 08:59 PM
mk1431's Avatar
Car: 89GTA Black, Black cloth
Engine: LB9 26,000 miles
Axle/Gears: 3.45 Australian 9 bolt
when your done cleaning real good check for very small cracks around the posts . Is it a maint free battery or do you have caps?
Old Jun 18, 2015 | 02:47 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
thanks TOM. and the battery does have caps. is that a battery I should avoid?
Old Jun 18, 2015 | 09:26 PM
UNCLE TOM's Avatar
if you have a battery with caps you should ck. water level every couple of weeks . water level should cover the top of the plates . to top off a cell use distilled water . to not keep water level covering top of plates is not good for battery . batteries that are ignored tend to LAST FAST . good luck .
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
justin57
Aug 20, 2015 07:05 PM
