Smog pump 'sensor'
Old Jul 12, 2015 | 03:14 AM
knightinblackar's Avatar
Car: 1984 Firebird S/E
Engine: 1985 2.8 MPFI
Transmission: 1985 T5 5 speed manual
Axle/Gears: 3.42/4.03
Smog pump 'sensor'
Hey guys,
I'm finally removing the 2.8 V6 motor from one shell to do up and put in the other shell!! Anyway my question is, when I was removing the air pump I found a little sensor attached to the side of it. I only found it because it broke off as I tried to unclip the electrics.
What is it and what does it do? Also how will it affect the ECM once it's removed from the pump or disconnected?
Thanks guys.
Old Jul 12, 2015 | 04:04 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Smog pump 'sensor'
Picture?
RBob.
Old Jul 13, 2015 | 01:13 AM
I'll get a pic thru the week, the car isn't at home so I'll take a trip up there and get one!
Old Jul 18, 2015 | 04:01 PM
Here are the pics
Old Jul 18, 2015 | 09:20 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
That is a solenoid as part of a AIR switching valve(s). Find what is broke of of and you likely require the whole piece.
RBob.
Old Jul 19, 2015 | 02:53 AM
Well I'm removing the smog system so what should I do with it? The pump is seized solid and the motor is out so it's coming off.
Old Jul 19, 2015 | 08:44 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Unplug the electrical connector from it and bin it. The ECM won't care if the smog pump is there or not.
RBob.
Old Jul 19, 2015 | 09:13 AM
Fabulous. Well I'll remove that section of the wiring altogether as the loom is out of the car. Thanks for the help on that!
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
italiano67
Dec 11, 2016 09:21 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
92camaroJoe
Aug 13, 2015 06:07 AM
