please help car wont start
Old Oct 14, 2015 | 10:46 PM
Juan Santos's Avatar
Hi I have a 1989 camaro v6 2.8 it was running and everything but when I press the pedal car will not ran it will feel like if I had a bad fuel filter o spark plugs. I change the fuel filter air filter spark plugs distributor cap and rotor ignition module. Started the car amd ran good on parking so I when to the streets for a test and after 10 minutes it started again. Check code and it gave me 34 and 42 I think it was the maf sensor and a cable from the ecm to the ignition module I think. I decided to clean the maf sensor iac valve and air presure temperature with an electric cleaner or something like that after an hour I put everything back and restarted the engine and it ran like crap all shaking like if it was out of time or something like that. I stop their for the day next day I try to check it I ckrank the engine it it wouldnt start. I already check for spark and its coming from the ignition coil to the distributor and from the distributor to the cable and it has spark. I check fuel and injectors are injecting fuel what can it be it has fuel and spark and air the engine should run please help me
Any comment will be helpful
Old Oct 15, 2015 | 11:45 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: please help car wont start
new thread isn't needed, keep it all in your original post
https://www.thirdgen.org/forums/v6/7...ont-start.html
Old Oct 15, 2015 | 11:51 AM
Sorry I still dont know how to use this site
Gunner242
Dec 25, 2015 04:49 PM
charlie1011
Oct 11, 2015 02:26 PM
Josh Sharp
Oct 8, 2015 01:12 PM
Tat2shag
Oct 7, 2015 11:34 PM
Luigytico09
Oct 1, 2015 08:46 AM
