92 rs not turning over
Old Nov 20, 2015 | 12:56 PM
cheezus's Avatar
Car: 92 RS
Hey guys I need a little help. I stopped the engine only to find it wouldn't start back. I've got lights gauge and radio all working. Everything works as usually just Jo action when I try to crank. I tried jumping it but no dice. It is automatic. I get nothing from the engine, no movement or noise (that I can notice) any ideas of what may be wrong? I haven't been able to try much because she is stranded but I should be getting her home soon.
Old Nov 20, 2015 | 03:13 PM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
Re: 92 rs not turning over
Does it click at all? My first guess is the starter is bad, try tapping it with a hammer and see if that gets it. Also make sure the car is in park or neutral, it won't start otherwise. Wiggle the handle on the shifter while in park and try again. When mine is in neutral it won't start again unless I push on the shifter a bit while I crank
Old Nov 20, 2015 | 05:21 PM
cheezus's Avatar
Car: 92 RS
Yeah it's in park. I tried that a few times. I don't notice a click. I was thinking the starter but wouldn't jumping kinda bypass that? I'm not too car savvy so I'm not positive but it seems like something electrical isn't right. I checked my connections they seem secure. The line from battery is in conduit that goes through firewall idk if it might be something along there but you'd think if that was the case I wouldn't get light or radio. I've been seeing a lot about vats and the ignition itself but I will definitely check that starter. Thanks for the input.
Old Nov 20, 2015 | 06:57 PM
cheezus's Avatar
Car: 92 RS
I don't hear a click it's kinda a soft hum maybe a buzz
Old Nov 20, 2015 | 11:50 PM
ktthecarguy's Avatar
On Probation
Car: 88 Camaro vert/86 SC
Engine: 355 tbi/2.8 V6
Transmission: 700R4/T5
Axle/Gears: 2.72 posi/3.42 open
Hi there,
Is that hum coming from around your back seat area? If so, that's some good news. That means the fuel pump is coming on when you turn the key, so at least some of your ignition circuitry is okay. Sounds more and more like a bad starter, or something bad in the starter circuitry.
Old Nov 21, 2015 | 09:17 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Sounds like a VATs issue. It prevents the starter from cranking along with preventing the fuel injectors from firing if the engine does crank (bad or bypassed enable relay).
Check the security light on the dash. If it stays on, its a VATs issue. Clean the chip in the key and wait 10 minutes before trying to crank it again.
RBob.
emnm53
Jan 6, 2016 01:29 AM
Thornburg
Dec 23, 2015 06:08 AM
Destro Camaro
Nov 2, 2015 07:22 AM
1nastyRS
Nov 1, 2015 06:26 PM
V1nom
Oct 26, 2015 11:20 PM
